PWM frequency higher than 100hz
Posted: Mon Apr 18, 2016 8:46 pm
I've been using NodeMCU (Lua) with PWM and I couldn't get PWM frequencies higher than 100hz.
I don't know if this is a hardware limitation (esp8266) or a framework limitation (nodeMCU).
so, my question is: is possible to get higher PWM frequencies using Sming? I don't mind sacrificing some range bits (from 10bits to 8bit for example) in order to get higher frequencies.
Thanks!
Thanks!
