WIFIO is a dual Arduino WIFI module (ESP8266+ATMEGA328P) FCC approve-able with transferable licence. Can use the 328P for I/O expansion also...
By Drakan1
#88924 hi, i been trying passing orientation data from adlx345 to esp8266 and it gives bad information, i can pass data from acelaration, but my code to pass orientation data won't work propertly. i will pass the code down here.
Scl ---D1
Sda---D2
Gnd--gnd
3v3---3v3
#include <Wire.h> // Wire library - used for I2C communication
int ADXL345 = 0x53; // The ADXL345 sensor I2C address
float X_out, Y_out, Z_out; // Outputs
float roll,pitch,rollF,pitchF=0;
//ESP8266 MASTER
Serial.begin(9600); // Initiate serial communication for printing the results on the Serial monitor
Wire.begin(); // Initiate the Wire library
// Set ADXL345 in measuring mode
Wire.beginTransmission(ADXL345); // Start communicating with the device
Wire.write(0x2D); // Access/ talk to POWER_CTL Register - 0x2D
// Enable measurement
Wire.write(8); // Bit D3 High for measuring enable (8dec -> 0000 1000 binary)
Wire.endTransmission();
delay(10);
//Off-set Calibration
//X-axis
Wire.write(0x1E);
Wire.write(1);
delay(10);
//Y-axis
Wire.write(0x1F);
Wire.write(-2);
delay(10);
//Z-axis
Wire.write(0x20);
Wire.write(-9);
delay(10);
// === Read acceleromter data === //
Wire.write(0x32); // Start with register 0x32 (ACCEL_XOUT_H)
Wire.endTransmission(false);
Wire.requestFrom(ADXL345, 6, true); // Read 6 registers total, each axis value is stored in 2 registers
X_out = ( Wire.read() | Wire.read() << 8); // X-axis value
X_out = X_out / 256; //For a range of +-2g, we need to divide the raw values by 256, according to the datasheet
Y_out = ( Wire.read() | Wire.read() << 8); // Y-axis value
Y_out = Y_out / 256;
Z_out = ( Wire.read() | Wire.read() << 8); // Z-axis value
Z_out = Z_out / 256;
// Calculate Roll and Pitch (rotation around X-axis, rotation around Y-axis)
roll = atan(Y_out / sqrt(pow(X_out, 2) + pow(Z_out, 2))) * 180 / PI;
pitch = atan(-1 * X_out / sqrt(pow(Y_out, 2) + pow(Z_out, 2))) * 180 / PI;
// Low-pass filter
rollF = 0.94 * rollF + 0.06 * roll;
pitchF = 0.94 * pitchF + 0.06 * pitch;
Serial.print(" X= ");
Serial.print(rollF);
Serial.print("/");
Serial.print(" Y= ");
Serial.print(pitchF);//ln na ultima linha
Serial.print("/");
Serial.print(" Z= ");
Serial.println(Z_out);
the output is like
x:89.50 y=-0.01 z=0.83
code only show acelaration (works)
#include <Wire.h>
#include <Adafruit_Sensor.h> // Adafruit sensor library
#include <Adafruit_ADXL345_U.h> // ADXL345 library
Adafruit_ADXL345_Unified accel = Adafruit_ADXL345_Unified(); // ADXL345 Object
Serial.begin(9600);
if(!accel.begin()) // if ASXL345 sensor not found
Serial.println("ADXL345 not detected");
while(1);
sensors_event_t event;
accel.getEvent(&event);
Serial.print("X: ");
Serial.print(event.acceleration.x);
Serial.print(" ");
Serial.print("Y: ");
Serial.print(event.acceleration.y);
Serial.print(" ");
Serial.print("Z: ");
Serial.print(event.acceleration.z);
Serial.print(" ");
Serial.println("m/s^2 ");
By Drakan1
#88950
schufti wrote:hm, from the ds the adlx345 is only accelerometer no compass, so I doubt you can get orientation from it?
i can get orientation in arduino, but when i compile de code in esp8266, the output is wrong.
By schufti
#88972 then most likely the library is not esp8266 compatible.
so look at the lib and in case ask over at adafruit (lib author) for solution.
they sell esp8266 and adlx345 so should provide compatible libs.
