Below, full code....
#include <IRremoteESP8266.h>
#include <IRrecv.h>
#include <BlynkSimpleEsp8266.h>
#include <EEPROM.h>
uint16_t RECV_PIN = D10;
IRrecv irrecv(RECV_PIN);
decode_results results;
const char* ssid = "ssid";
const char* password = "pswd";
char auth[] = "auth";
int LED1 = D0;
int LED2 = D1;
int LED3 = D2;
int LED4 = D3;
int LED5 = D4;
int LED6 = D5;
int LED7 = D6;
int LED8 = D7;
int swval[] = {0,0,0,0,0,0,0,0,0};
int errpin = D9;
WiFiServer server(80);
BLYNK_WRITE(V1)
int pd1 = param.asInt();
appchng(LED1,pd1,1);
BLYNK_WRITE(V2)
int pd2 = param.asInt();
appchng(LED2,pd2,2);
BLYNK_WRITE(V3)
int pd3 = param.asInt();
appchng(LED3,pd3,3);
BLYNK_WRITE(V4)
int pd4 = param.asInt();
appchng(LED4,pd4,4);
BLYNK_WRITE(V5)
int pd5 = param.asInt();
appchng(LED5,pd5,5);
BLYNK_WRITE(V6)
int pd6 = param.asInt();
appchng(LED6,pd6,6);
BLYNK_WRITE(V7)
int pd7 = param.asInt();
appchng(LED7,pd7,7);
BLYNK_WRITE(V8)
int pd8 = param.asInt();
appchng(LED8,pd8,8);
void appchng(int k, int q, int m){
digitalWrite(k, q);
swval[m]=q;
EEPROM.write(m, q);
EEPROM.commit();
//Serial.begin(9600);
irrecv.enableIRIn(); // Start the receiver
delay(10);
//eeprom
EEPROM.begin(512);
swval[1]=EEPROM.read(1);
swval[2]=EEPROM.read(2);
swval[3]=EEPROM.read(3);
swval[4]=EEPROM.read(4);
swval[5]=EEPROM.read(5);
swval[6]=EEPROM.read(6);
swval[7]=EEPROM.read(7);
swval[8]=EEPROM.read(8);
pinMode(LED1, OUTPUT);
pinMode(LED2, OUTPUT);
pinMode(LED3, OUTPUT);
pinMode(LED4, OUTPUT);
pinMode(LED5, OUTPUT);
pinMode(LED6, OUTPUT);
pinMode(LED7, OUTPUT);
pinMode(LED8, OUTPUT);
pinMode(errpin, OUTPUT);
digitalWrite(LED1, swval[1]);
digitalWrite(LED2, swval[2]);
digitalWrite(LED3, swval[3]);
digitalWrite(LED4, swval[4]);
digitalWrite(LED5, swval[5]);
digitalWrite(LED6, swval[6]);
digitalWrite(LED7, swval[7]);
digitalWrite(LED8, swval[8]);
digitalWrite(errpin, HIGH);
// Connect to WiFi network
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
delay(5000);
server.begin();
Blynk.config(auth);
Blynk.connect();
BLYNK_CONNECTED() {
Blynk.virtualWrite(V1, swval[1]);
delay(100);
Blynk.virtualWrite(V2, swval[2]);
delay(100);
Blynk.virtualWrite(V3, swval[3]);
delay(100);
Blynk.virtualWrite(V4, swval[4]);
delay(100);
Blynk.virtualWrite(V5, swval[5]);
delay(100);
Blynk.virtualWrite(V6, swval[6]);
delay(100);
Blynk.virtualWrite(V7, swval[7]);
delay(100);
Blynk.virtualWrite(V8, swval[8]);
delay(100);
void relayswitch(int i,int j, int v){
if(swval[j]==1){
digitalWrite(i, LOW);
swval[j]=0;
EEPROM.write(j, 0);
}else{
digitalWrite(i, HIGH);
swval[j]=1;
EEPROM.write(j, 1);
EEPROM.commit();
Blynk.virtualWrite(v, swval[j]);
if(WiFi.status() != WL_CONNECTED) {
digitalWrite(errpin,HIGH);
}else{
digitalWrite(errpin,LOW);
Blynk.run();
//ir receiveing code
//CHANGE VALUE ACCORDINGLY
if (irrecv.decode(&results)) {
unsigned int ircode = results.value;
//Serial.println(ircode);
if(ircode==13601142){
relayswitch(LED1,1,V1);
}else if(ircode==13625622){
relayswitch(LED2,2,V2);
}else if(ircode==13609302){
relayswitch(LED3,3,V3);
}else if(ircode==13576662){
relayswitch(LED4,4,V4);
}else if(ircode==13627662){
relayswitch(LED5,5,V5);
}else if(ircode==13592982){
relayswitch(LED6,6,V6);
}else if(ircode==13595022){
relayswitch(LED7,7,V7);
}else if(ircode==4294967295){
relayswitch(LED8,8,V8);
irrecv.resume(); // Receive the next value
delay(100);
if (!client) {
return;
while(!client.available()){
delay(1);
String request = client.readStringUntil('\r');
client.flush();
// Set LED according to the request
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println(""); // do not forget this one
client.println("<!DOCTYPE HTML>");
client.println("<html>");
client.println("<meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0\">");
client.println("<title>Amits Room</title>");
client.println("<br><br>");
// Return the response LED1
client.print("Relay 1 is now: ");
// Control LED 1
if (request.indexOf("/LED1=ON") != -1) {
digitalWrite(LED1, LOW);
swval[1] = 0;
EEPROM.write(1, 0);
EEPROM.commit();
if (request.indexOf("/LED1=OFF") != -1) {
digitalWrite(LED1, HIGH);
swval[1] = 1;
EEPROM.write(1, 1);
EEPROM.commit();
if(swval[1]==0){client.print("ON");}
if(swval[1]==1){client.print("OFF");}
client.println("<a href=\"/LED1=ON\"\"><button>TURN ON </button></a>");
client.println("<a href=\"/LED1=OFF\"\"><button>TURN OFF </button></a><br />");
// Return the response LED2
client.print("Relay 2 is now: ");
// Control LED 2
if (request.indexOf("/LED2=ON") != -1) {
digitalWrite(LED2, LOW);
swval[2] = 0;
EEPROM.write(2, 0);
EEPROM.commit();
if (request.indexOf("/LED2=OFF") != -1) {
digitalWrite(LED2, HIGH);
swval[2] = 1;
EEPROM.write(2,1);
EEPROM.commit();
if(swval[2]==0){client.print("ON");}
if(swval[2]==1){client.print("OFF");}
client.println("<a href=\"/LED2=ON\"\"><button>TURN ON </button></a>");
client.println("<a href=\"/LED2=OFF\"\"><button>TURN OFF </button></a><br />");
// Return the response LED3
client.print("Relay 3 is now: ");
// Control LED 3
if (request.indexOf("/LED3=ON") != -1) {
digitalWrite(LED3, LOW);
swval[3] = 0;
EEPROM.write(3, 0);
EEPROM.commit();
if (request.indexOf("/LED3=OFF") != -1) {
digitalWrite(LED3, HIGH);
swval[3] = 1;
EEPROM.write(3, 1);
EEPROM.commit();
if(swval[3]==0){client.print("ON");}
if(swval[3]==1){client.print("OFF");}
client.println("<a href=\"/LED3=ON\"\"><button>TURN ON </button></a>");
client.println("<a href=\"/LED3=OFF\"\"><button>TURN OFF </button></a><br />");
// Return the response LED4
client.print("Relay 4 is now: ");
// Control LED 4
if (request.indexOf("/LED4=ON") != -1) {
digitalWrite(LED4, LOW);
swval[4] = 0;
EEPROM.write(4, 0);
EEPROM.commit();
if (request.indexOf("/LED4=OFF") != -1) {
digitalWrite(LED4, HIGH);
swval[4] = 1;
EEPROM.write(4, 1);
EEPROM.commit();
if(swval[4]==0){client.print("ON");}
if(swval[4]==1){client.print("OFF");}
client.println("<a href=\"/LED4=ON\"\"><button>TURN ON </button></a>");
client.println("<a href=\"/LED4=OFF\"\"><button>TURN OFF </button></a><br />");
// Return the response LED5
client.print("Relay 5 is now: ");
// Control LED 5
if (request.indexOf("/LED5=ON") != -1) {
digitalWrite(LED5, LOW);
swval[5] = 0;
EEPROM.write(5, 0);
EEPROM.commit();
if (request.indexOf("/LED5=OFF") != -1) {
digitalWrite(LED5, HIGH);
swval[5] = 1;
EEPROM.write(5, 1);
EEPROM.commit();
if(swval[5]==0){client.print("ON");}
if(swval[5]==1){client.print("OFF");}
client.println("<a href=\"/LED5=ON\"\"><button>TURN ON </button></a>");
client.println("<a href=\"/LED5=OFF\"\"><button>TURN OFF </button></a><br />");
// Return the response LED6
client.print("Relay 6 is now: ");
// Control LED 6
if (request.indexOf("/LED6=ON") != -1) {
digitalWrite(LED6, LOW);
swval[6] = 0;
EEPROM.write(6, 0);
EEPROM.commit();
if (request.indexOf("/LED6=OFF") != -1) {
digitalWrite(LED6, HIGH);
swval[6] = 1;
EEPROM.write(6, 1);
EEPROM.commit();
if(swval[6]==0){client.print("ON");}
if(swval[6]==1){client.print("OFF");}
client.println("<a href=\"/LED6=ON\"\"><button>TURN ON </button></a>");
client.println("<a href=\"/LED6=OFF\"\"><button>TURN OFF </button></a><br />");
// Return the response LED7
client.print("Relay 7 is now: ");
// Control LED 7
if (request.indexOf("/LED7=ON") != -1) {
digitalWrite(LED7, LOW);
swval[7] = 0;
EEPROM.write(7, 0);
EEPROM.commit();
if (request.indexOf("/LED7=OFF") != -1) {
digitalWrite(LED7, HIGH);
swval[7] = 1;
EEPROM.write(7, 1);
EEPROM.commit();
if(swval[7]==0){client.print("ON");}
if(swval[7]==1){client.print("OFF");}
client.println("<a href=\"/LED7=ON\"\"><button>TURN ON </button></a>");
client.println("<a href=\"/LED7=OFF\"\"><button>TURN OFF </button></a><br />");
// Return the response LED8
client.print("Relay 8 is now: ");
// Control LED 8
if (request.indexOf("/LED8=ON") != -1) {
digitalWrite(LED8, LOW);
swval[8] = 0;
EEPROM.write(8, 0);
EEPROM.commit();
if (request.indexOf("/LED8=OFF") != -1) {
digitalWrite(LED8, HIGH);
swval[8] = 1;
EEPROM.write(8, 1);
EEPROM.commit();
if(swval[8]==0){client.print("ON");}
if(swval[8]==1){client.print("OFF");}
client.println("<a href=\"/LED8=ON\"\"><button>TURN ON </button></a>");
client.println("<a href=\"/LED8=OFF\"\"><button>TURN OFF </button></a><br />");
client.println("</html>");
delay(1);
