Obvious things to look for would be code yes sure. Other things would be the browser you are using the connection you are making etc...
Funny thing though I guess a better explanation would likely help.
It may just be a bug if it is a wan ip that you are using make sure your port 80 is being forwarded for your device in your router under port forwarding settings for your device. So if your device's IP is 192.168.1.23 you will want to setup port forwarding to external port 80 . Once forwarded things should work if you request things from your external IP find that by googling what is my ip or look at your routers status page wan IP should be listed somewhere on your router.
I am curious I think there is some important information on your setup being missed here share as much info as you can if needed maybe tomorrow you can PM me your IP and I can check it out for myself and verify that there are no text boxes indeed.
Anyhow take care as I said it may just be a bug I don't recall what version you said you are using if you are using ap and station mode both this may be causing issues as stated.
Where I buy my ESP8266 boards from... (Banggood)
