Current News
By forlotto
#50942 From what I gather there is a version of the esp01 that has a 1MB flash and should work for espbasic v3.x ...
The version is as it says in the title the ESP01S
I have one on order will update and let you know if it works when I get it via slow boat may be a while but maybe some one out there can confirm this already?
Enjoy
-forlotto
By ardhuru
#51023 Yes indeed; the easiest way to identify the 1 MB version is the fact that it usually is a black PCB, as against the blue one for the 512 KB.
Another attractive idea is to buy either, and ramp it up with chips of a higher capacity. They're very cheap, and fairly easy to do.
By Multifitter
#51039
ardhuru wrote:Yes indeed; the easiest way to identify the 1 MB version is the fact that it usually is a black PCB, as against the blue one for the 512 KB.
....shown here...
http://hackaday.com/2016/07/16/your-esp ... ore-214157
By forlotto
#51059 hrmmm yes I was unsure of any compatibility issues this seems cool though any spi flash will work then.
