Current News
By Mmiscool
#29539 Added servo command.
You can now control servo motors.
SERVO:
Will set the angle of a servo connected to the the pin.
Angle must be between 0 and 180.
servo {pin no} {value or variable 0 to 180}
By Mmiscool
#29743 ADDED ELSE TO IF THEN COMMAND. BUG FIX FOR EVALUATING = & ==
if bla = 5 then print "true" else print "false" is now some thing that works. I actually forgot all about implementing an else until today.
Did a bug fix for evaluating = and ==
= is for comparing numbers
== is for comparing strings
Documentation in language reference on site updated to reflect changes.
Also made goto, gosub and button commands more robust on finding branch labels for jumps.
By Mmiscool
#30077 Added timer command.
Will allow for doing things at regular intervals.
Code: Select alltimer 5000 [do.some.stuff]
print "going to do some stuff in a bit"
button "Click me to exit" [Exit.ThisThing]
wait
[do.some.stuff]
print "Doing Some Stuff"
wait
[Exit.ThisThing]
