AJB2K3 wrote:Should Programmer be "Arduino as ISP"?
ArduinoESP target doesn't care about the Programmer Menu, it is hard-coded under the hood to any USB-Serial, but Port is important.
Explore... Chat... Share...
Markus Gritsch wrote:I think FS stands for file system. You have to use the "Staging" version of the Esp-Arduino package, which adds this.
Sketch uses 391,740 bytes (37%) of program storage space. Maximum is 1,044,464 bytes.
Global variables use 53,672 bytes (65%) of dynamic memory, leaving 28,248 bytes for local variables. Maximum is 81,920 bytes.
warning: espcomm_sync failed
error: espcomm_open failed
