http://esp8266basic.com
A BASIC interpreter for your ESP
Working now on Autodrop3d. A 3d printer with automatic part ejection system. https://autodrop3d.com
Explore... Chat... Share...
void OLED_setxy(int x,int y,int onepointthree){
if(onepointthree) x+=2;
spi_write_command(0xB0+y) ; //set page address
spi_write_command(0x10 | ((x>>4) & 0x0F)) ; //set high col address
spi_write_command(x & 0x0f) ; //set low col address
