Place to put your Basic demos and examples
By AusUser
#62340 Thanks for your post. The i2c scanner has confirmed the address is 0x3c for the oled. And using the wire libiary i've set
Code: Select all // Initialize the OLED display using Wire library
 SSD1306  display(0x3c, D2, D1);
From the IDE I've run the SSD1306DrawingDemo and the display is garbled, I can make our the word "working" though.
By trackerj
#62348 Simplest OLED Display test code:
Code: Select alllet v = 100
i2c.setup(4,5)
lcdbl 1
oledcls
oledprint "Hello", 0, 0
oledprint v, 3, 3
wait
Assumptions:
- SDA, SCL = GPIO4,5
- Proper I2C pull-up resistors
- i2cscanner() detects properly the OLED Display, etc,etc
By AusUser
#62426 Thanks for you reply. Using the SSD1306SimpleDemo and setting
Code: Select all#include "SH1106.h" // alias for `#include "SSD1306Wire.h"`
and
Code: Select all// Initialize the OLED display using Wire library
// SSD1306  display(0x3c, D3, D5);
SH1106 display(0x3c, D2, D1);
I was able to confirm it was working.
