flywire wrote:Output and line 20 from debug as shown in my previous post. Full code follows:Code: Select allcls
let pinNo = 0
let pinStat = 0
print "Pin Number"
textbox pinNo
print "Pin Stat"
textbox pinStat
button "Set Pin", [SetThePin]
button "Set Pin PWM", [SetThePinPWM]
button "Exit ", [TestExit]
wait
[SetThePin]
print "Pin Number"
print pinNo
print "Pin Stat"
print pinStat
po pinNo pinStat
wait
[SetThePinPWM]
print "Pin Number"
print pinNo
print "Pin Stat"
print pinStat
pwo pinNo pinStat
wait
[TestExit]
end ' See more at: http://www.esp8266.com/viewtopic.php?f=40&t=4849#sthash.67P35vQf.dpuf
Okay easy fix!
Mistake i used to make playing with examples early on..
So your line 20 and 28 need to be changed just a little
line 20 should read io(po, pinNo, pinStat)
line 28 should read io(pwo, pinNo, pinStat)
i could post the fixed code for you to swap but I'm pretty new myself and I find getting in there and changing/modifying/fixing these examples myself has been the best learning experience !
also the driving lessons and beginners guide thread are worth reading, rereading and reading again!
