0 is ON and 1 is OFF in my case anyways.
Even the LED on the board by itself pin2 write a zero to it toggle it off so to speak bingo it turns on.
Write a 1 to it and it will turn off ...
Mighty confusing for someone first starting off with it for days I couldn't figure out what it was that was going wrong with working with LUA I kept trying to set stuff high until one day I gave up and said I'm going to try to write a 0 to it and just see what happens well it just happened to be the pin tied to the LED so when that turned on I thought hrmmm wow I have something completely screwed up in my logic...
I always thought 1 was on state and 0 was off state but low and behold this is not true quite the oddity for me at first when I set out on a path with very little information it was a lot of brute force so to speak.
enjoy my fault I missed the previous line you typed ... Good to hear all is well though have fun testing I will tell you this will make you life 10 times easier then having to solder in connections ... I am going to be making harnesses that you just plug to both sides of the Node MCU and then just break out from there 2 15pin connectors and from there you can break out however you wish more or less for me I will only be using approx 10 pins I believe so should be relatively simplistic once I figure everything out but before I start making any harnessing etc... I need to study a bit more on the programming side of things as well.
Where I buy my ESP8266 boards from... (Banggood)
