YIPPY KI AI ... Was able to upload my html code to my 12-E on 1st try
and the refresh proxy count displays properly ....amazing ,, thank you
Will try my ESP-201 later...
Is there any way to view how much memory I have left. I need to add some more code.
also when I reboot my page displays under you page [ie]
VAR EDIT RUN SETTINGS
Simple Basic Interpreter
[ my page ] -------------- How do I remove your page
Do you have any suggestions how to update the vars on the webpage
I will need to retrieve them over the serial port , that is currently acting like a logging output
!!!!!!!!!! ESP-201 had problems loading FW @ 512
tried loading nodemcu , won't load had to replug power
loaded latest basic ok
cannot load my pgm fail default/6 and later tried several times
!!Noted that you must try to open the name you want to save as before saving else you get default/1~~x
The security stuff is looking ok
Loaded back to Nodemcu
How about putting some kind if FW ID # on boot msg
