By Electroguard
#48805 This is a comprehensive and versatile switched relay Unit - it is fully configurable, and pre-configured to work with the cheap Sonoff modules, is udp network controllable, plus it can be used as a thermostat or humidity stat. It also has many features that lend itself well to Home Automation & Control usage.
See Chapter 8 of the Driving Lessons for more info...
http://www.esp8266.com/viewtopic.php?f=40&t=9868&start=4#p46961
Code: Select all'SonOff Relay Module
memclear
let debugmode = "normal" 'debugmode options are: silent, normal, verbose
let ledpin = 13
let relaypin = 12
let dhtsensor = 11
let dhtpin = 14
let settemp = 24
let sethumid = 50
let frequency = 5000  ' sensor read update frequency
let settemp = 24
let sethumid = 50
let statmode = "TooHot"
let ledlogic = 1    'Default led pin off state (allows configuring led pin for active high or active low operation)
let relaylogic = 0  'Default relay pin off state (allows configuring relay pin for active high or active low operation)
let buttonpin = 0 'Using onboard GOIO00 flashing button by default, change to suit (needs pullup resistor).
interrupt buttonpin, [PRESSED]  ' Will require pull-up resistor to work.
let nowait = 0
let localIP = ip()
gosub [IPSPLIT]
let shoutmsg = "All Blinks" ' The default msg shown in the broadcast msg window
gosub [READVARS]
if (title == "" or title == " ") then let title = "Electroguard Relay Module - Sonoff version 1 "
if (localname == "" or localname == " ") then let localname = "Node" & nodeIP
if globalname == "" then let globalname = "ALL"
if groupname == "" then let groupname = "Relay"
if udpport == "" then let udpport = "5001"
if (description == "" or description == " ") then let description = "Network Relay module. "
if debugmode == "" then let debugmode = "normal"
if buttonmode == "" then let buttonmode = "MultiMode"
if userpage == "" then let userpage = "Normal"
if startmode == "" then let startmode = "Off"
if startmode == "On" then
 if relaylogic == 0 then io(po,relaypin,1) else io(po,relaypin,0)
 if ledlogic == 0 then io(po,ledpin,1) else io(po,ledpin,0)
 if relaylogic == 0 then io(po,relaypin,0) else io(po,relaypin,1)
 if ledlogic == 0 then io(po,ledpin,0) else io(po,ledpin,1)
endif
udpbegin udpport
udpbranch [UDPMAIN]
[DHTINIT]
if startmode = "Stat" then
 dht.setup(dhtsensor, dhtpin)
 timer frequency, [HOME]
 timer 0
endif
[HOME]
cls
if startmode == "UserOnOff" then goto [USERONOFF]
print " "
button " ? " [HELP]
wprint " "
wprint title
wprint " "
wprint "- Developed on V2 Alpha 24"
print " "
if startmode == "Stat" then goto [STATMODE]
if startmode == "UserToggle" then goto [USERTOGGLE]
html "<BR>"
html "NODE DETAILS  "
html "<BR>" & "<BR>"
html "Local name:  " & localname
html "<BR>"
html "Global name:  " & globalname
html "<BR>"
html "Group name:  " & groupname
html "<BR>"
html "Local IP address:  " & localIP
if description <>"" then html "Description:  " & description
wprint "<BR><BR><BR>"
gosub [SENDMSG]
button "ON" [RELAYON]
wprint " "
button "Toggle Relay" [TOGGLE]
wprint " "
button "OFF" [RELAYOFF]
wprint "<BR><BR>"
button "Cycle ON [OFF]" [CYCLEON]
wprint "  "
wprint "On delay: " & ondelay
wprint "  "
wprint "On duration: " & onduration
wprint "<BR><BR>"
button "Cycle OFF [ON]" [CYCLEOFF]
wprint "  "
wprint "Off delay: " & offdelay
wprint "  "
wprint "Off duration: " & offduration
wprint "<BR><BR>"
wprint "Local button mode = " & buttonmode
wprint "<BR><BR>"
wprint " "
print "<BR>"
button "Configuration" [CONFIG]
wait
[TOGGLE]
if debugmode <> "silent" then udpreply localname & " Toggle acknowledged"
if io(laststat,relaypin) = 0 then io(po,relaypin,1) else io(po,relaypin,0)
if io(laststat,ledpin) = 0 then io(po,ledpin,1) else io(po,ledpin,0)
goto [HOME]
[CYCLEON]
if debugmode <> "silent" then udpreply localname & " CycleOn acknowledged"
if len(params) > 0 then gosub [GETCYCLEPARS]
if ondelay <> 0 then delay ondelay
if onduration == 0 then goto [HOME]
delay onduration
goto [RELAYOFF]
[CYCLEOFF]
if debugmode <> "silent" then udpreply localname &  " CycleOff acknowledged"
if offdelay <> 0 then delay offdelay
if offduration == 0 then goto [HOME]
delay offduration
goto [RELAYON]
[RELAYON]
if debugmode <> "silent" then udpreply localname & " On acknowledged"
if io(laststat,relaypin) <> relaylogic then goto [HOME]
goto [HOME]
[RELAYOFF]
if debugmode <> "silent" then udpreply localname & " Off acknowledged"
if io(laststat,relaypin) == relaylogic then goto [HOME]
goto [HOME]
[STATMODE]
wprint "<BR><BR>"
if statmode == "TooHot" then goto [TOOHOT]
if statmode == "TooCold" then goto [TOOCOLD]
if statmode == "TooWet" then goto [TOOWET]
if statmode == "TooDry" then goto [TOODRY]
[TOODRY]
wprint " Irrigation switch"
wprint "<BR><BR>"
wprint "Humidity=" & dht.hum()
wprint "<BR><BR>"
button "<" [HUMID<]
wprint " "
wprint sethumid
wprint " "
button ">" [HUMID>]
if dht.hum() < sethumid and io(laststat,relaypin) == relaylogic then goto [RELAYON]
if dht.hum() > sethumid and io(laststat,relaypin) <> relaylogic then goto [RELAYOFF]
wait
[TOOWET]
wprint " Ventilation switch"
wprint "<BR><BR>"
wprint "<BR><BR>"
button "<" [HUMID<]
wprint " "
wprint sethumid
wprint " "
button ">" [HUMID>]
if dht.hum() > sethumid and io(laststat,relaypin) == relaylogic then goto [RELAYON]
if dht.hum() < sethumid and io(laststat,relaypin) <> relaylogic then goto [RELAYOFF]
wait
[TOOCOLD]
wprint " Heating switch"
wprint "<BR><BR>"
wprint "temp="
wprint dht.temp()
wprint "<BR><BR>"
button "<" [TEMP<]
wprint " "
wprint settemp
wprint " "
button ">" [TEMP>]
if dht.temp() < settemp and io(laststat,relaypin) == relaylogic then goto [RELAYON]
if dht.temp() > settemp and io(laststat,relaypin) <> relaylogic then goto [RELAYOFF]
wait
[TOOHOT]
wprint " Cooling Fan switch"
wprint "<BR><BR>"
wprint "temp="
wprint dht.temp()
wprint "<BR><BR>"
button "<" [TEMP<]
wprint " "
wprint settemp
wprint " "
button ">" [TEMP>]
if dht.temp() > settemp and io(laststat,relaypin) == relaylogic then goto [RELAYON]
if dht.temp() < settemp and io(laststat,relaypin) <> relaylogic then goto [RELAYOFF]
wait
[HUMID>]
let sethumid = sethumid + 1
goto [HOME]
[HUMID<]
let sethumid = sethumid - 1
goto [HOME]
[TEMP>]
let settemp = settemp + 1
goto [HOME]
[TEMP<]
let settemp = settemp - 1
goto [HOME]
[USERONOFF]
wprint |<body>|
wprint |<div style="text-align: center;">|
wprint |<table style="text-align: left; width: 100%;" border="0"|
wprint | cellpadding="2" cellspacing="2">|
wprint |  <tbody>|
wprint |    <tr>|
wprint |      <td style="text-align: right;">|
button " ? " [HELP]
wprint |</td>|
wprint |      <td style="text-align: center;color: rgb(102, 51, 255);"><big><big>|
wprint localname
wprint |    </big></big></td>|
wprint |      <td style="text-align: left;">|
button " ! " [CONFIG]
wprint |</td>|
wprint |    </tr>|
wprint |  </tbody>|
wprint |</table>|
print " "
wprint |<br>|
wprint "Status="
wprint |<big style="color: rgb(0, 153, 0);">OFF|
wprint |</big><br> |
wprint |<big style="color: rgb(204, 0, 0);">ON|
endif
wprint "<BR><BR>"
wprint |<big><big>|
wprint "    "
wprint | </big></big><br>|
wprint |</div>|
wprint |</body>|
wprint "<BR><BR>"
wait
[USERTOGGLE]
wprint "<BR><BR><BR><BR><BR><BR>"
wprint |<!DOCTYPE html>|
wprint |<html>|
wprint |<head>|
wprint |<style>|
wprint | .bigbutton, input[type="button"], input[type="submit"] { |
wprint |  display: inline-block;|
wprint |  padding: 15px 25px;|
wprint |  font-size: 24px;|
wprint |  cursor: pointer;|
wprint |  text-align: center;|
wprint |  color: #fff;|
if io(laststat,relaypin)=0 then
 wprint |background-color: #4CAF50; /* Green */|
 wprint |background-color: #f44336; /* Red */|
endif
wprint |  border: 2px solid black;|
wprint |  border-radius: 15px;|
'wprint |  box-shadow: 0 9px #999;|
wprint |}|
wprint | .box, input[type="button"], input[type="submit"] { |
wprint |}|
wprint |</style>|
wprint |</head>|
wprint |<body>|
wprint |<div style="font-size: 32px; text-align: center;">|
if io(laststat,relaypin) = 0 then button "ON" [TOGGLE] else button "OFF" [TOGGLE]
wprint |</div>|
wprint |</body>|
wprint |</html>|
wait
[READVARS]
read Title title
read Name localname
read Global globalname
read Group groupname
read Description description
read Userpage userpage
read Startmode startmode
read Debugmode debugmode
read Buttonmode buttonmode
read UDPport udpport
read Ondelay tmp
if tmp == "" then let ondelay = 0 else let ondelay = val(tmp)
read Offdelay tmp
if tmp == "" then let offdelay = 2000 else let offdelay = val(tmp)
read Onduration tmp
if tmp == "" then let onduration = 5000 else let onduration = val(tmp)
read Offduration tmp
if tmp == "" then let offduration = 9000 else let offduration = val(tmp)
read Blinks tmp
if tmp == "" then let numblinks = 5 else let numblinks = val(tmp)
return
[SAVE]
if debugmode <> "silent" then udpreply localname & " Save to Flash acknowledged"
write Title title
write Name localname
write Global globalname
write Group groupname
write Description description
write UDPport udpport
write Debugmode debugmode
write Buttonmode buttonmode
write Ondelay ondelay
write Offdelay offdelay
write Onduration onduration
write Offduration offduration
write Blinks numblinks
write Startmode startmode
write Userpage userpage
goto [DHTINIT]
return
[BLINKS]
if debugmode <> "silent" then udpreply localname & " Blinks acknowledged. Params=" & params
let oldstate = io(laststat,ledpin)
io(po,ledpin,ledlogic)
if len(params) > 0 then let numblinks = val(params) else let numblinks = 6
let params = ""
delay 200
for count = 1 to numblinks
delay 600
delay 400
next count
delay 2000
io(po,ledpin,oldstate)
goto [HOME]
[BROADCAST]
if instr(upper(shoutmsg),"LOCAL") == 1 then goto [LOCAL]
udpwrite netIP & "255", val(udpport), shoutmsg
wait
[LOCAL]
let msg = shoutmsg
'udpreply msg
goto [MAIN]
[SENDMSG]
html " Broadcast message  "
textbox shoutmsg
button "Send" [BROADCAST] ' broadcast the message
wprint " "
wprint "    (use name LOCAL to respond to commands sent from the same local node, eg: LOCAL BLINKIP)."
return
[UDPMAIN]
let msg = udpread()
let lastmsg = msg
[MAIN]
if debugmode == "verbose" then udpreply localname & " msg received: " & msg
let name = upper(word(msg, 1))
let command = ""
let params = ""
let pos = len(name)
if len(msg) > pos then command = upper(word(msg, 2))
let pos = instr(upper(msg),command) + len(command)
if len(msg) > pos then params = mid(msg,(pos)) else params = ""
if debugmode = "verbose" then udpreply localname & " Name=" & name
if debugmode = "verbose" then udpreply localname & " Command=" & command
if debugmode = "verbose" then udpreply localname & " Params=" & params
if instr(upper(localname),name) > 0 then name = upper(localname) ' complete partial name to full name
if name == "LOCAL" then goto [LOCAL_COMMANDS]                    ' handle locally-sent commands
if name == upper(localname) then goto [LOCAL_COMMANDS]           ' handle localname commands
if name == upper(groupname) then goto [GROUP_COMMANDS]           ' handle any group commands
if name == upper(globalname) then goto [GLOBAL_COMMANDS]         ' handle any global commands
if debugmode <> "silent" then udpreply localname & " Error: NAME not recognised in " & msg
wait
[LOCAL_COMMANDS]
'let lastmsg = msg
' Add any new unique local commands here (change the test udreply to gosub to your appropriate subroutine handler
if command == upper("ON") then goto [RELAYON]
if command == upper("OFF") then goto [RELAYOFF]
if command == upper("CYCLEON") then goto [CYCLEON]
if command == upper("CYCLEOFF") then goto [CYCLEOFF]
if command == upper("ONDELAY") then goto [ONDELAY]
if command == upper("OFFDELAY") then goto [OFFDELAY]
if command == upper("ONDURATION") then goto [ONDURATION]
if command == upper("OFFDURATION") then goto [OFFDURATION]
if command == upper("BUTTONMODE") then goto [BUTTONMODE]
if command == upper("TOGGLE") then goto [TOGGLE]
if command == upper("SAVE") then goto [SAVE]
gosub [COMMON_COMMANDS]
if debugmode <> "silent" then udpreply localname & " Error: COMMAND " & command & " not recognised in " & msg
return
[COMMON_COMMANDS]
' Commands recognised by all nodes. Add any new common commands here
if command == upper("Report") then goto [REPORT]
if command == "?" then goto [DECLARE]
if command == upper("Blinks") then goto [BLINKS]
if command == upper("BlinkIP") then goto [BLINKSHORTIP]
if command == upper("BlinkShortIP") then goto [BLINKSHORTIP]
if command == upper("BlinkFullIP") then goto [BLINKFULLIP]
if command == upper("Exit") then goto [EXIT]
if command == upper("Reset") then goto [RESET]
if debugmode <> "silent" then udpreply localname & " Error: common COMMAND " & command & " not recognised in " & msg
return
[GROUP_COMMANDS]
' Sent prefixed by groupname.
' Add any new group-only commands here, eg: "Groupname  NewGroupCommand"
[GLOBAL_COMMANDS]
' Sent prefixed by globalname, eg: "Globalname NewGlobalCommand"
' Add any new global-only commands here,
goto [LOCAL_COMMANDS] ' branch to look for local_commands
[DECLARE]
if debugmode <> "silent" then udpreply localname & " Declare IP acknowledged "
udpreply localname & "   " & localIP
goto [HOME]
return
[REPORT]
if debugmode <> "silent" then udpreply localname & " Report request acknowledged "
udpreply "Sending data"  ' change to include whatever info needs to be sent back
return
[ONDELAY]
if debugmode <> "silent" then udpreply localname &  " OnDelay " & params & " acknowledged"
let ondelay = val(params)
params = ""
goto [HOME]
[OFFDELAY]
if debugmode <> "silent" then udpreply localname & " OffDelay " & params & " acknowledged"
let offdelay = val(params)
params = ""
goto [HOME]
[ONDURATION]
if debugmode <> "silent" then udpreply localname &  " OnDuration " & params & " acknowledged"
let onduration = val(params)
params = ""
goto  [HOME]
[OFFDURATION]
if debugmode <> "silent" then udpreply localname & " OffDuration " & params & " acknowledged"
let offduration = val(params)
params = ""
goto  [HOME]
[BLINKFULLIP]
if debugmode <> "silent" then udpreply localname &  " BlinkIP acknowledged "
let blinkon = 200
let blinkoff = 400
let blinkpause = 1000
let blinkgap = 1400
if ledlogic == 0 then io(po,ledpin,0) else io(po,ledpin,1) ' turn led off
delay blinkpause
for pos = 1 to len(localIP)
  let digitchr = mid(localIP,pos,1)
  if digitchr == "." then
    delay blinkgap
    if digitchr = "0" then let digit = val("10") else digit = val(digitchr)
    for count = 1 to digit
      delay blinkon
      delay blinkoff
    next count
    delay blinkpause
  end if
next pos
delay blinkgap
if nowait == 0 then wait else nowait = 0
return
[BLINKSHORTIP]
let blinkon = 200
let blinkoff = 400
let blinkgap = 1400
let ip = val(nodeIP)
delay blinkpause
let ipstr = str(ip)
let iplength = len(ipstr)
for pos = 1 to iplength
  let digit = mid(ipstr,pos,1)
  for temp = 1 to digit
    delay blinkon
    delay blinkoff
  next temp
  delay blinkpause
next pos
delay blinkpause
return
[IPSPLIT]
pos = instrrev(localIP,".")
netIP = left(localIP,pos)
nodeIP = mid(localIP,pos+1)
return
[HELP]
cls
print " "
button "X"  [HOME]
wprint "    "
wprint title & " - HELP"
print ""
wprint "Syntax:      NODENAME   COMMAND   [OPTIONAL PARAMETERS]  "
wprint " (name and commands are NOT case-sensitive, parameters ARE case-sensitive)"
wprint "<BR>"
wprint "Example:   LOCAL   BLINKS   12  "
wprint " (use node name of LOCAL to address commands to local node instead of remote network nodes)"
wprint "<BR><BR>"
wprint "ON - turns relay instantly On and it stays On."
wprint "<BR>"
wprint "OFF - turns relay instantly Off and it stays Off."
wprint "<BR>"
wprint "TOGGLE - instantly changes relay state."
wprint "<BR>"
wprint "CycleON - turns relay On after optional OnDelay, then optionally turns back Off after optional OnDuration."
wprint "  (useful for automatic lights etc)"
wprint "<BR>"
wprint "OnDelay - 0 for no On delay."
wprint "<BR>"
wprint "OnDuration - 0 to stay On."
wprint "<BR>"
wprint "CycleOFF - turns relay Off after optional OffDelay, then optionally turns back On after optional OffDuration."
wprint "  (useful for power-down reboots of routers etc) "
wprint "<BR>"
wprint "OffDelay - 0 for no Off delay."
wprint "<BR>"
wprint "OffDuration - 0 to stay Off. "
wprint "<BR>"
wprint "Blinks [numblinks] - blinks the local led to aid location. Optional parameter over-rides default of 5 blinks."
wprint "<BR>"
wprint "BlinkFullIP - locally blinks the full IP byte digits (10 blinks for 0)."
wprint "<BR>"
wprint "BlinkShortIP - locally blinks the last IP byte digits (the wifi subnet address will already be known)."
wprint "<BR>"
wprint "Report - returns the nodes IP address via UDP. "
wprint "<BR>"
wprint "Save - saves variables to non-volatile flash memory."
wprint "<BR>"
wprint "Reset - restarts the node. "
wprint "<BR>"
wprint "Exit - shuts down the node. "
wprint "<BR>"
wprint "ButtonMode - allows different behaviour for local button. "
wprint " FlipSwitch allows standard flip-type light switch to be used instead of momentary button."
wprint " MultiMode allows quick blip to Toggle relay, or press and quck "
wprint " hold (less than 1 sec) for BlinkShortIP, or press and long hold (greater than 1.5 sec) for BlinkFullIP."
wprint "<BR><BR>"
wprint "This script is configured for the Sonoff module, but is adaptable for alternative "
wprint "switched relay modules."
wprint "<BR>"
wprint "Sonoff pins - button=0, led=12, relay=13. Ledlogic=0 (active low), relaylogic=1 (Sonoff relay is active high)."
wprint "<BR><BR>"
button "Home" [HOME]
wait
[CONFIG]
cls
print " "
button "X" [DHTINIT]
wprint " "
wprint title & " - CONFIG"
print " "
html "<BR>"
html "Title: "
textbox title
html "<BR><BR>"
html "Local name:  "
textbox localname
wprint " "
html "Group name:  "
textbox groupname
html " "
textbox globalname
html "<BR><BR>"
html "UDP port    "
textbox udpport
html "<BR><BR>"
textbox description
html "<BR><BR>"
wprint "Local button mode   "
dropdown "MultiMode,BlinkFullIP,BlinkShortIP,Toggle,FlipSwitch" buttonmode
wprint " "
wprint " selects different behaviour for local button. MultiMode is button-speed dependent (see Help ?)."
wprint "<BR><BR>"
wprint "Start mode"
dropdown "On,Off,Stat,UserToggle,UserOnOff" startmode
wprint " "
wprint " Allows selecting a pre-defined startup mode."
wprint "<BR><BR>"
wprint "DHT sensor"
dropdown "None, 11, 21, 22" dhtsensor
wprint " "
wprint " Stat mode "
wprint " "
dropdown "TooHot, TooCold, TooWet, TooDry" statmode
wprint " "
wprint " Temperature setting="
textbox settemp
wprint " Humidity setting="
textbox sethumid
wprint "<BR><BR>"
wprint " On delay: "
textbox ondelay
wprint " "
wprint " "
wprint " On duration: "
textbox onduration
wprint "<BR><BR>"
wprint " Off delay: "
textbox offdelay
wprint " "
wprint " "
wprint " Off duration: "
textbox offduration
'wprint " <BR><BR><BR>"
wprint "<BR><BR>"
wprint "Number of Blinks: "
textbox numblinks
wprint "<BR><BR>"
wprint "Debug mode   "
dropdown "silent,normal,verbose" debugmode
wprint " "
wprint " UDP messages - silent=none, normal=acknowledgements, verbose=debug info."
button "Home" [DHTINIT] ' don't save edits
wprint " "
wprint " "
button "Save" [SAVE] ' save details to persistent memory
wprint " "
wprint " "
wprint "HOME loses changes at power-off, SAVE holds changes in non-volatile flash memory. "
wait
[BUTTONMODE]
if debugmode <> "silent" then udpreply localname &  " ChangeButtonMode acknowledged"
let buttonmode = params
let params = ""
goto [HOME]
return
[PRESSED]
if debugmode <> "silent" then udpreply localname &  " Local button pressed"
if buttonmode == "FlipSwitch" then
 if io(laststat,buttonpin) = 0 then goto [RELAYON] else goto [RELAYOFF]
endif
if buttonmode == "Toggle" then
 if io(laststat,buttonpin) = 0 then goto [TOGGLE]
endif
if buttonmode == "BlinkShortIP" then
 if io(laststat,buttonpin) = 0 then goto [BLINKSHORTIP]
endif
if buttonmode == "BlinkFullIP" then
 if io(laststat,buttonpin) = 0 then goto [BLINKFULLIP]
endif
if io(laststat,buttonpin) = 0 then let start = millis() else let stop = millis()
if stop > start then
  if stop-start < 500 then goto [TOGGLE]
  if stop-start < 1000 then goto [BLINKSHORTIP]
  if stop-start > 1500 then goto [BLINKFULLIP]
endif
goto [HOME]
[EXIT]
print "<BR>" & "Node " & upper(localname) & " with IP address " & localIP & " has been shut down."
udpwrite netIP & "255", val(udpport), "Node " & upper(localname) & " has been shut down." & "<BR>"
for count = 1 to 5
po ledpin 0
delay 70
po ledpin 1
delay 200
next count
[RESET]
reboot
By viscomjim
#48979 Electroguard, THIS IS COOL!!! Still pouring over your code, but man, this seems excellent. Can't wait to try it! Thank you for posting.
By forlotto
#49411 I don't know why but after skimming through your code an automated watering system comes to mind would be useful if my garden were close enough to reach it with a hose let me tell you what. But quite a bit of code and lots of looks and handling different situations very useful and the UDP stuff seems to be catching on rather well so the more examples of this the merry.
Thanks for sharing electrogaurd.
-forlotto
