By Mmiscool
#30848 Just posted an update. Tested your page.
It seems to work :) :D :mrgreen:
It will save the whole thing.
Please test and let me know.
You should use the built in textbox, and button commands in side basic for the interactive bits.
By xtal
#30881 Tried on ESP-12E and ESP-201 results not good!
using esp-12E
0
Loading Settings Files0
Loading Settings FilesWIFIname
WIFIpass
APname
APpass
LoginKey
0
0
default/1 ---- issued save
default/2
default/3
default/4
default/5
default/6
default/7
default/8
default/9
default/10
default/11
default/12
default/13
J3C¦ü19ØmûüSimple Basic Interperter For ESP8266... --unit
rebooted
1
join AP security settings are cleared
setup/sav security
0
WIFIpass
APname
APpass
LoginKey
0saved again
default/1~~35 chrome says saved
when open only displayed thru 1st <textarea>
security is cleaed again
reopen = same only displayed thru 1st <textarea>cols=17 rows=14
tried save again
a1/1~~~~37 chrome says saved
when open only displayed thru 1st <textarea>cols=17 rows=14
LOAD ESP-210
connect 192.168.1.13
setup-save security select edit
save A2
get default/1~~16 chrome says saved
file open failed default 17~~~~37
try save A3
get default/1~~15 chrome says saved
file open failed default 16~~~~37
open A2 and A3 show nothing
reflashing-----
connect 192.168.1.28
setup settings ===
file open failed
WIFIpass
file open failed
APname
file open failed
APpass
file open failed
LoginKey
file open failed
0select edit
paste/save B1
default/1 rebooted
setup/save settings
select edit
paste/save B2
must set up login again
WIFIpass
APname
APpass
LoginKey
file open failed
0
back to edit / screen is new
B2/1~~6
B2/7~~B2/37
file open failed
Flash back to nodeMCU---------------
By Mmiscool
#30983 Problem with it removing your settings when you do a save in the editor is fixed.
By xtal
#31344 YIPPY KI AI ... Was able to upload my html code to my 12-E on 1st try
and the refresh proxy count displays properly ....amazing ,, thank you
Will try my ESP-201 later...
Is there any way to view how much memory I have left. I need to add some more code. :mrgreen:
also when I reboot my page displays under you page [ie]
VAR EDIT RUN SETTINGS
Simple Basic Interpreter
[ my page ] -------------- How do I remove your page :?:
Do you have any suggestions how to update the vars on the webpage :?:
I will need to retrieve them over the serial port , that is currently acting like a logging output :?:
!!!!!!!!!! ESP-201 had problems loading FW @ 512
tried loading nodemcu , won't load had to replug power
loaded latest basic ok
cannot load my pgm fail default/6 and later tried several times
!!Noted that you must try to open the name you want to save as before saving else you get default/1~~x
The security stuff is looking ok
Loaded back to Nodemcu
How about putting some kind if FW ID # on boot msg
