By xtal
#31453 basic was able to load my code on ESP-13 , its just has more flash like 12E.....and smaller solder pads..yuk!! :roll:
units came with sdk1.1.1 v 0.25 AI-thinker --- was able to load sdk 1.4.0 v 0.50 AT command set...
How do you concatenate Wprint ?
with nodeMCU C:send"('ttttext'..var..'texxxt')"
So how to do with basic?????
By Mmiscool
#31462 I am not familiar too much with node MCU lua.
The wprint command simple puts whatever you want at the end the of the html buffer.
I suggest you use several wprint lines to accomplish your gold.
wprint "Stuff before the variable"
wprint variable
wprint "stuff after variable"
By xtal
#31463 tonight I added about 10 vars then saved again , of course the vars did not display in my Wpage when re-opening the saved file about 15-20 lines displayed and the remainder intermixed the remaining text with attempt to display Wpage.......
[ie] started display EDIT page the appended/intermixed my Wpage display.
another bug in the woods.....!!!!
By Mmiscool
#31466 Please post problem code.
I want to try and duplicate.
