By xtal
#31522 Here is the code -same as before with added vars ... I've only tried this on the ESP-13 and NOT others
it displayed good a couple of times until I changed some var values and also replace about 4 hard values in the Wpage cod with var names and resaved after about the 3rd save it intermixed..
vars val changed cdeg0, ppm0,ph,
Wpage changed 15 to rfh, cdeg0,ppm0,ph
since the var usage was not correct this may have contributed to the problem..
the intermixing started after textarea col-70 lines=14 ,,, which is where previous display problems occurred[ie]
display stopping...
Once this happens you clear rhe edit window save , open you see no data , then add back you code it will be immediately intermix... had to reflash ....
Is there any way to see how much memory is being used ??
Is there any way to determine flash size with your flash code before flashing , like maybe maybe writing the 1st
8 char of each page and checking when addr0 is over overwritten [ie] address wrap..just a thought :mrgreen:
Code: Select allrfctr=0
adc_id = 0
adc_value = 512
k1=0.11
p00='P'
apc0='11111'
ppm0='1770'
cdeg0='25.1'
kta0='0.01'
lo0='12'
hi0='20'
prb='01.0'
ph='7.0'
sbuf=""
rfh = '15'
Ipage = 'http://i.imgur.com/KS1dPa7.png'
wprint "<!DOCTYPE HTML>"
wprint "<html lang='en-US'>"
wprint "<head><meta http-equiv='refresh' content='15' ></head>"
wprint "<script type = 'text/javascript'>"
wprint "var timeInSecs;"
wprint "var ticker;function startTimer(secs){"
wprint "timeInSecs = parseInt(secs)-1;"
wprint "ticker = setInterval('tick()',1000);}"
wprint "function tick() {"
wprint "var secs = timeInSecs;"
wprint "if (secs>0) {timeInSecs--;} else {clearInterval(ticker);"
wprint "startTimer(15);}document.getElementById('countdown').innerHTML = secs;} startTimer(15);"
wprint "</script><body><div>"
wprint "<table bgcolor='Lawngreen' border='1' cellpadding='5'>"
wprint "<th><h1>ESP8266 Blinker Thing!</h1></th>"
wprint "<td><IMG SRC='http://i.imgur.com/KS1dPa7.png' LEFT='1' WIDTH='120' HEIGHT='60' BORDER='1'></td>"
wprint "<th id='countdown'>15</th></table><br>"
wprint "<div><textarea name='cmd1s' cols='70' rows='14'></textarea></div><br>"
wprint "<div><textarea name='cmd2s' cols='70' rows='6'></textarea></div><br>"
wprint "<div><table bgcolor='Yellow' border='1' cellpadding='5'>"
wprint "<tr><th>Sensor</th><th>TempC</th><th>TempF</th><th>PPMcntr</th><th>PPM__</th><th>Adj__1</th><th>Adj__2</th></tr>"
wprint "<tr><td>DS18B20P</td><td>25.9</td><td>78.6</td><td>43708</td><td>1676</td><td>1644.9</td><td>1644.2</td></tr>"
wprint "<tr><th>Probe-K</th><th>Pool-PH</th><th>PH-Adj</th><th>ADC Value</th></tr>"
wprint "<tr><td>01.0</td><td>7.0</td><td>7</td><td bgcolor='Red'>902</td></tr></table></div><br>"
wprint "<form action='' method='POST'>"
wprint "<input type='submit' name='m_do' value='BLINK' style='padding:5px;10px;'>"
wprint "<input type='submit' name='m_do' value='RD_ADC' style='padding:5px;10px;'>"
wprint "<input type='submit' name='m_do' value='TEMP_DN' style='padding:5px;10px;'>"
wprint "<input type='submit' name='m_do' value='TEMP_UP' style='padding:5px;10px;'><br>"
wprint "'CMD:'<input type='text' name='m_do' value='' maxlength='100' style='padding:5px;10px;'>"
wprint "<input type='submit' value='Submit'></form><br></body></html>"
wait
By kingedem
#31671 Hi Micheal,
With new firmware, the pages are not opening with default IP 192.168.4.1 and at 80% times opening with dynamic ip allocated via wifi router (192.168.1.6).
By forlotto
#31684 I hope you know that every password and username you share on a forum is likely saved on a wordlist somewhere you may want to not use that username or password for anything anymore lol just saying you should for good measure always edit out passwords that you use and usernames for good measure maybe this is something you do not use heh IDK really the choice is yours.
Sorry for the off topic and interruption. I just dunno if people are aware of this or if they plain just don't care if it is the later there is nothing I can say when someone chooses to learn the hard way it is equally is hard to tell them the easy way.
