Re: SPI and 1-wire
Posted: Fri Nov 06, 2015 6:47 pm
Added this to the current source.
Thank you so much. Need all the help possible.
I did how ever change the "ti"command a bit.
To keep with the convention for the other commands the identifier for the device is first. Then the variable to place the status in to.
temp deviceNo variableName
if ( Param0 == "temp" | Param0 == "ti")
valParam1 = GetMeThatVar(Param1).toInt();
// call sensors.requestTemperatures() to issue a global temperature
// request to all devices on the bus
sensors.requestTemperatures(); // Send the command to get temperatures
SetMeThatVar(Param2, String(sensors.getTempCByIndex(valParam1)));
return;
