Using the following:
- ESP8266 Microcontroller
- RobotDyn AC Dimmer
**Question**: First up, Is this even possible using J5 over WiFi with an ESP8266?
I've read there are latency issues that cause flickering.
Assuming it is nonetheless possible...
Here's what I understand so far:
Connect the Dimmer's PWM pin to a PWM-enabled ESP GPIO
Connect Dimmer's ZC pin to another ESP GPIO set for Digital *Read*? or *Write*?
**Question**: On the J5 side, then what?
Been looking at this StackExchange page for clues
Among the key commands in Arduino IDE is `attachInterrupt` (e.g. `attachInterrupt(0, zero_crosss_int, RISING)`
**Question**: Is there an equivalent to `attachInterrupt()` in J5? If not, is there a way to directly call the command from J5?
