By viscomjim
#38933 Just ordered a couple of these...
http://www.aliexpress.com/snapshot/7249 ... 5885483851
It looks like there should be no problem in hacking basic into this. However, I think I read somewhere that you are limited to 3 channels of pwm. Is this correct? If so, you can use the two other mosfets for just on and off of something else, I suppose. It looks like RX and TX are readily available.
They are on their way on the slow boat, so I will post results when they get here. Not bad for a couple of bucks more than a nodeMCU board...
EDIT....
Looks like someone hacked it, so here is some more info on this board....
http://chaozlabs.blogspot.com/2015/08/e ... -hack.html
By Mmiscool
#39062 ESP8266 basic uses the arduino environment. It wold seem that there is no limit.
