Re: Memory Layout
Posted: Sat Sep 06, 2014 2:43 am
hackrid wrote:How did you do it?
Looks like RE the XTCOM protocol to read single memory location and Python scripts to perform massive dump
Open Community Forum for ESP8266, Come share Arduino and IoT (Internet of Things)
https://www.esp8266.com/
Memory Protection/MMU: Region Protection
System RAM start address / size 0x60000000 / 64M
System ROM start address / size 0x50000000 / 16M
Local Memory
Instruction RAM [0] start address / size 0x40000000 / 1M [busy]
Instruction RAM [1] start address / size 0x40100000 / 1M [busy]
Instruction ROM start address / size 0x40200000 / 1M [busy]
Data RAM [0] start address / size 0x3ffc0000 / 256K [busy]
Data RAM [1] start address / size 0x3ff80000 / 256K [busy]
Data ROM start address / size 0x3ff40000 / 256K [busy]
XLMI start address / size 0x3ff00000 / 256K [busy]
Vector configuration
Reset Vector start address / size 0x50000000 / 0x300
Kernel (Stacked) Exception Vector start address / size 0x40000030 / 0x1c
User (Program) Exception Vector start address / size 0x40000050 / 0x1c
Double Exception Vector start address / size 0x40000070 / 0x10
Level 2 Interrupt Vector start address / size 0x40000010 / 0xc
Level 3 Interrupt Vector (NMI vector) start address / size 0x40000020 / 0xc
Bert wrote:Just FYI, here are the (more or less) meaningful strings in the binary:Code: Select allets_unpack_flash_code
ets %s,rst cause:%d, boot mode:(%d,%d)
Jan 8 2013
wdt reset
ets_main.c
unknown reset
user code done
waiting for host
load 0x%08x, len %d, room %d
flash read err, %s
tailtail
chksum 0x%02x
csum 0x%02x
csum err
ho %d tail %d room %d
sp %p
sf_dump[%d] a0: 0x%08x a1: 0x%08x a2: 0x%08x a3: 0x%08x
epc1=0x%08x, epc2=0x%08x, epc3=0x%08x, excvaddr=0x%08x, depc=0x%08x
Fatal exception (%d):
eprintf no bno b0123456789
<null>
ets_timer.c
bootup , addr 0x%08x
no rds
sip bogus rx done
rx done unknown
sip bogus tx
seq %u, %u ds %p
tx unknown
rxiq_get_mis: s_pwr=%lld, %d-%d,
stagstag: CGAIN=%d FGAIN=%d, DC_OS=(%d,%d), DAC=(%d,%d)
pwctrl: rate_i=%d, target_power=%d, detect_power=%d
num_k=%d, power_out=%d,
reg_i=%d, indata=%d
txiq: tone_atten=%d
txiq_gain=%d
txiq_phase=%d
bt:
Seems like the AT-stuff is implemented in flash memory, yay!
Bert wrote:@kongo: you have been dumping the I-RAM instead of the I-ROM.
From the lx106 configuration file:Code: Select allMemory Protection/MMU: Region Protection
Local Memory
I wouldn't count on the sizes being correct (as in: actually implemented in hardware), though.
