I also saw a post somewhere about an eclipse setup, also on windows. I guess I should be able to get something working
![Wink ;)](./images/smilies/icon_e_wink.gif)
Explore... Chat... Share...
sharkx wrote:Just a beginner here, but the AT command mode seems like a pain-in-the-*** to work with. The commands work just fine in terminal mode, but once you try to hook up a microcontroller, things get awkward.
Not being able to find much on this, I was wondering if anyone here would know about an API frame-based firmware, much like the xBees from Digi have.
Thanks in advance for any ideas on this matter.
