Re: "universal I/O bridge"
[quote="eriksl"]Something is definitely broken, indeed. I have flashed a "plain" image on a 32 Mbit device and it keeps resetting. Needs to be checked out. The "ota" image works.
Thanks for input. I managed to flash the "ota" image v17. Hopefully this way i will be able to update OTA.
I'm having a hard time going from v11 style commands to the latest version . For example setting GPIO2 to PWM was
And setting the PWM value to maximum was
Can you please translate this to the updated parameters? I tried for about an hour to set the GPIO 2 as PWM with
thanks
gm 2 pwm
gs 2 65535
im pin=2 mode=outputa
thanks
