Re: "universal I/O bridge"
Posted: Mon Mar 18, 2019 11:41 am
My first try to bring up the UART bridge and struggling a bit. Using lastest Release 19 (bin), ESP1 successfully flashed and it is in my networks as client. I can access the command port 24.
On ESP1 the TX and RX are wired (expected loop function for test).
Configured each parameter of UART 0 and cw & r. 300e71
Can open bridge port configured under bp with putty, switching local echo to off, but get no echo via bridge, so UART bridge seem not to work. I connected in RAW mode of putty.
Tried a lot, but now I run out of ideas.
Oberservations:
1) bp was initial not set to default 23. It was 0. Could be changed and stored by cw and accessed after reset.
2) bt set to 0 and bridge link is endless open
3) ct default was initial set to 90 not 0 as desribed. Setting to 0, cw, but command port closing after 90sec!
4) command like s, wcc, sc working. sc-task uart posted increased by two when pressing key+CR in bridge port terminal. task uart failed stuck at 643. uart updated counted frequently.
5) using uw 0 123456 but no reception on putty terminal.
Is it normal, that defauls are not correct (e.g. bp and ct)? Timeout of port 24 normal? Could it be a flash issue?
Any idea how to debug the bridge behavior?
Maybe the new inverting function does have also wrong default and one of RX / TX is inverted? How to check or to be configured in non inverting mode?
Did not observed any hang-up of command port beside that port closing after 90sec inactivity. Maybe this is interpreted as hang-up.
Oberservations:
