manageConnections(): dropping 10417291 now= 2054447821 - last= 2051447248 ( 3000573 ) > timeout= 3000000
but when I run this code with the AP constantly scanning the wifi ... I get more timeouts and at least one wdt reset was observed ... So I am now convinced that the wdt reset and remaining timeouts are being caused by wifi scanning and/or os_timer stuff ... I have noticed that the timer seams to stay set across resets ... I am thinking about splitting the call to connectToBestAP() function out of the stationScanCb() function so that program flow is returned faster (so that other things can get done ... like process nodesync messages ...) also ... I'm going to eliminate the os_timer and use a loop counter instead ... the timer interrupt is firing off at a bad time (place in code) ... might also have to add for checks if we are scanning before dropping connections ...
making progress
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
On a side note, did you have any luck with the BSSID approach and in trying to make all SSIDs the same?
Nikhil J wrote:@Sfranzyshen: Oh I didn't notice that change in comparison equation. You're right. Making the comparison roll-over proof is surely a better way to do it.
Yes I have a devel version of this code located here: https://github.com/sfranzyshen/easyMesh/tree/devel
It use a single ssid for the mesh ... and I still have to follow through with the client wifi device roaming and the captive dns portal ... to kick off a "login to network" popup ... and also ... so that we don't need to know the AP's IP address from the client wifi device web browser ... and will work across all mesh APs wifi connections ... but I took a break from expanding things to fixing the core (keeps crashing
![Sad :(](./images/smilies/icon_e_sad.gif)
![Smile :)](./images/smilies/icon_e_smile.gif)
