Page 12 of 13
Re: News! A WebIDE for 8266 Lua programming over the air
PostPosted: Mon Dec 22, 2014 8:41 am
by sej7278
Harold L. wrote:You could continue from step No.5 of the tutorial: http://nodelua.org/doc/tutorial/make-your-first-node/, step No.6 and 7 is also important.
The Node WebIDE is designed for programming with Lua more convenient, it's a different concept with the cloud service, just make a try will give you some different experience ;)
nah i'm not a cloud ide fan, went through all that crud with the spark core.
so you don't have any way to use ip other than via your cloud? there's no way to run a webserver or telnet server like with the AT or nodemcu (yuk) firmware?
PostPosted: Mon Dec 22, 2014 8:50 am
by picpic020960
Bonjour ,
why not the bin file of the project in github folder ?
all the projects with ESP are not easy to compile !
win / linux / toolchain / expressif / sdk 0.9.n
it's like opensource when the source is in folder
and it's easy to test the app
what you think about ?
PostPosted: Tue Dec 23, 2014 4:19 am
by Harold L.
Client socket API had been partly implemented in NodeLua, but undocumented. I will be very appreciated if you can improve it.
You can find them in app/lua/lnode_net_socket.c
It wasn't enabled by default, you can edit app/lua/linit.c and uncomment the line to use it:
//{LUA_LNODE_NET_NAME, luaopen_lnode_net},
PostPosted: Tue Dec 23, 2014 4:25 am
by Harold L.
picpic020960 wrote:Bonjour ,
There is prebuild firmware on the website, you'll find it here: http://nodelua.org/doc/download_firmware/
