By per
#6210 Hi,
I am sittting in Beijing and have bought some ESP8266 modules and I have several years experience in MCU and serial data development.
The modules are powered from a good supply and I have a USB-3.3V TTL converter connected.
Ch_PD is 3.3V
GPIO 0 connected to GND
TX and RX connected
GND and VDD connected.
I have also tried to start up the module with GPIO 0 unconnected but the data string from the module remains the same..
When I turn on the power the red led turns on and I can see a quick flash of the blue led. My serial terminal software is set up to 74880 baud and the serial communication the module sends out is below
ets Jan 8 2013,rst cause:1, boot mode:(5,0)
waiting for host
I can not get the module to accept any AT commands and I can not get the module to communicate with any firmware upgrade PC application. Ihave also used a logic analyzer to see the and the module does not respond to anything.
Could anyone please tell me what I am doing wrong?
By per
#6242 Simple answer ..
MTD0 (also known as GPIO15) : GPIO0 : GPIO2 are the pins that control the boot mode on the ESP-07 module I have.
To be able to download new firmware the module must boot in mode 1 ( GND : GND : 3V3 ) by setting GPIO15 : GPIO0 : GPIO2
To run the module with the new downloaded firmware the module must boot in mode 3 ( GND : 3V3 : 3V3 )
For my modules when a pin should be 3.3V it is enough to leave it not connected and if it should be 0 I have connected it to GND.
Maybe this is common knowledge but I thought I would provide the solution that worked for me anyway if someone else runs into the same problem.
