By mr_roboto9
#56118 Hi !
I Wonder how long esp memory will work. I woud save two bytes every 30 s
to 0 and 1 address in esp eeprom ( I know this two bytes will be safe to esp flash, but in arduino ide it's still called eeprom).
By mikronauts
#56126 Check the data sheet for your specific eeprom part.
Normally eeproms have 100k - 1M write cycles per location these days.
You could implement a simple wear levelling algorithm to extend the lifetime.
Now assuming the worst case 100k writes, if you write every 30 seconds, you could write your values for approximately 50,000 minutes, which is approx. 34.7 days
