ESP8266 ESP-12E Problems with Wire.h & Wire.cpp
PostPosted: Tue Mar 14, 2017 2:34 pm
by desmop
Hello,
I'm new to code programming, I could use some help. This is my first time posting to this forum. I Have a ESP-12E module that I'm having problems with. The Wire library seems to be the problem. I've posted my code and the error log. I would appreciate any help I could get. I have been working on this project for weeks, sometimes another set of eyes helps. Thanks in advance.
Arduino: 1.8.1 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, 9600, 4M (3M SPIFFS)"
Error Log:
Arduino: 1.8.1 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, 9600, 4M (1M SPIFFS)"
Build options changed, rebuilding all
In file included from C:\Users\Patrick\Desktop\Digital Hydrometer\pinkhydrometer\pinkhydrometer.ino:5:0:
C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.h: In function 'void getTemp()':
C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.h:70:13: note: candidate 1: uint8_t TwoWire::requestFrom(int, int, int)
uint8_t requestFrom(int, int, int);
C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.h:64:12: note: candidate 2: size_t TwoWire::requestFrom(uint8_t, size_t, bool)
size_t requestFrom(uint8_t address, size_t size, bool sendStop);
libraries\Wire\Wire.cpp.o:(.bss._ZN7TwoWire12transmittingE+0x0): multiple definition of `TwoWire::transmitting'
sketch\Wire.cpp.o:C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/Stream.h:92: first defined here
libraries\Wire\Wire.cpp.o: In function `_GLOBAL__sub_I__ZN7TwoWire8rxBufferE':
C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.cpp:160: multiple definition of `TwoWire::write(unsigned char const*, unsigned int)'
sketch\Wire.cpp.o:sketch/Wire.cpp:160: first defined here
libraries\Wire\Wire.cpp.o:(.bss._ZN7TwoWire13rxBufferIndexE+0x0): multiple definition of `TwoWire::rxBufferIndex'
libraries\Wire\Wire.cpp.o:(.bss._ZN7TwoWire14rxBufferLengthE+0x0): multiple definition of `TwoWire::rxBufferLength'
libraries\Wire\Wire.cpp.o:(.bss._ZN7TwoWire8rxBufferE+0x0): multiple definition of `TwoWire::rxBuffer'
libraries\Wire\Wire.cpp.o: In function `TwoWire::read()':
C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.cpp:185: multiple definition of `TwoWire::read()'
sketch\Wire.cpp.o:sketch/Wire.cpp:185: first defined here
libraries\Wire\Wire.cpp.o: In function `TwoWire::peek()':
C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.cpp:194: multiple definition of `TwoWire::peek()'
sketch\Wire.cpp.o:sketch/Wire.cpp:194: first defined here
libraries\Wire\Wire.cpp.o:(.bss._ZN7TwoWire13txBufferIndexE+0x0): multiple definition of `TwoWire::txBufferIndex'
libraries\Wire\Wire.cpp.o:(.bss._ZN7TwoWire14txBufferLengthE+0x0): multiple definition of `TwoWire::txBufferLength'
libraries\Wire\Wire.cpp.o: In function `TwoWire::flush()':
C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.cpp:201: multiple definition of `TwoWire::flush()'
sketch\Wire.cpp.o:sketch/Wire.cpp:201: first defined here
libraries\Wire\Wire.cpp.o: In function `TwoWire::available()':
C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.cpp:171: multiple definition of `TwoWire::available()'
sketch\Wire.cpp.o:sketch/Wire.cpp:171: first defined here
libraries\Wire\Wire.cpp.o:(.bss._ZN7TwoWire8txBufferE+0x0): multiple definition of `TwoWire::txBuffer'
libraries\Wire\Wire.cpp.o: In function `TwoWire::write(unsigned char)':
C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.cpp:145: multiple definition of `TwoWire::write(unsigned char)'
sketch\Wire.cpp.o:sketch/Wire.cpp:145: first defined here
libraries\Wire\Wire.cpp.o: In function `TwoWire::TwoWire()':
C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/Print.h:45: multiple definition of `TwoWire::TwoWire()'
sketch\Wire.cpp.o:C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266/Print.h:45: first defined here
libraries\Wire\Wire.cpp.o: In function `TwoWire::begin(int, int)':
C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.cpp:57: multiple definition of `TwoWire::begin(int, int)'
sketch\Wire.cpp.o:sketch/Wire.cpp:57: first defined here
libraries\Wire\Wire.cpp.o: In function `TwoWire::pins(int, int)':
C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.cpp:65: multiple definition of `TwoWire::pins(int, int)'
sketch\Wire.cpp.o:sketch/Wire.cpp:65: first defined here
libraries\Wire\Wire.cpp.o: In function `TwoWire::begin()':
C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.cpp:70: multiple definition of `TwoWire::begin()'
sketch\Wire.cpp.o:sketch/Wire.cpp:70: first defined here
libraries\Wire\Wire.cpp.o: In function `TwoWire::begin(unsigned char)':
C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.cpp:73: multiple definition of `TwoWire::begin(unsigned char)'
sketch\Wire.cpp.o:sketch/Wire.cpp:73: first defined here
libraries\Wire\Wire.cpp.o: In function `TwoWire::status()':
C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.cpp:80: multiple definition of `TwoWire::status()'
sketch\Wire.cpp.o:sketch/Wire.cpp:80: first defined here
libraries\Wire\Wire.cpp.o: In function `TwoWire::begin(int)':
C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.cpp:84: multiple definition of `TwoWire::begin(int)'
sketch\Wire.cpp.o:sketch/Wire.cpp:84: first defined here
libraries\Wire\Wire.cpp.o: In function `TwoWire::setClock(unsigned int)':
C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.cpp:88: multiple definition of `TwoWire::setClock(unsigned int)'
sketch\Wire.cpp.o:sketch/Wire.cpp:88: first defined here
libraries\Wire\Wire.cpp.o: In function `TwoWire::setClockStretchLimit(unsigned int)':
C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.cpp:92: multiple definition of `TwoWire::setClockStretchLimit(unsigned int)'
sketch\Wire.cpp.o:sketch/Wire.cpp:92: first defined here
libraries\Wire\Wire.cpp.o: In function `TwoWire::requestFrom(unsigned char, unsigned int, bool)':
C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.cpp:96: multiple definition of `TwoWire::requestFrom(unsigned char, unsigned int, bool)'
sketch\Wire.cpp.o:sketch/Wire.cpp:96: first defined here
libraries\Wire\Wire.cpp.o: In function `TwoWire::requestFrom(unsigned char, unsigned char, unsigned char)':
C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.cpp:106: multiple definition of `TwoWire::requestFrom(unsigned char, unsigned char, unsigned char)'
sketch\Wire.cpp.o:sketch/Wire.cpp:106: first defined here
libraries\Wire\Wire.cpp.o: In function `TwoWire::requestFrom(unsigned char, unsigned char)':
C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.cpp:110: multiple definition of `TwoWire::requestFrom(unsigned char, unsigned char)'
sketch\Wire.cpp.o:sketch/Wire.cpp:110: first defined here
libraries\Wire\Wire.cpp.o: In function `TwoWire::requestFrom(int, int)':
C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.cpp:114: multiple definition of `TwoWire::requestFrom(int, int)'
sketch\Wire.cpp.o:sketch/Wire.cpp:114: first defined here
libraries\Wire\Wire.cpp.o: In function `TwoWire::requestFrom(int, int, int)':
C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.cpp:118: multiple definition of `TwoWire::requestFrom(int, int, int)'
sketch\Wire.cpp.o:sketch/Wire.cpp:118: first defined here
libraries\Wire\Wire.cpp.o:(.bss._ZN7TwoWire9txAddressE+0x0): multiple definition of `TwoWire::txAddress'
libraries\Wire\Wire.cpp.o: In function `TwoWire::beginTransmission(unsigned char)':
C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.cpp:123: multiple definition of `TwoWire::beginTransmission(unsigned char)'
sketch\Wire.cpp.o:sketch/Wire.cpp:123: first defined here
libraries\Wire\Wire.cpp.o: In function `TwoWire::beginTransmission(int)':
C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.cpp:129: multiple definition of `TwoWire::beginTransmission(int)'
sketch\Wire.cpp.o:sketch/Wire.cpp:129: first defined here
libraries\Wire\Wire.cpp.o: In function `TwoWire::endTransmission(unsigned char)':
C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.cpp:133: multiple definition of `TwoWire::endTransmission(unsigned char)'
sketch\Wire.cpp.o:sketch/Wire.cpp:133: first defined here
libraries\Wire\Wire.cpp.o: In function `TwoWire::endTransmission()':
C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.cpp:141: multiple definition of `TwoWire::endTransmission()'
sketch\Wire.cpp.o:sketch/Wire.cpp:141: first defined here
libraries\Wire\Wire.cpp.o: In function `TwoWire::onReceiveService(unsigned char*, int)':
C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.cpp:208: multiple definition of `TwoWire::onReceiveService(unsigned char*, int)'
sketch\Wire.cpp.o:sketch/Wire.cpp:208: first defined here
libraries\Wire\Wire.cpp.o: In function `TwoWire::onRequestService()':
C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.cpp:231: multiple definition of `TwoWire::onRequestService()'
sketch\Wire.cpp.o:sketch/Wire.cpp:231: first defined here
libraries\Wire\Wire.cpp.o: In function `TwoWire::onReceive(void (*)(int))':
C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.cpp:244: multiple definition of `TwoWire::onReceive(void (*)(int))'
sketch\Wire.cpp.o:sketch/Wire.cpp:244: first defined here
libraries\Wire\Wire.cpp.o: In function `TwoWire::onRequest(void (*)())':
C:\Users\Patrick\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire/Wire.cpp:248: multiple definition of `TwoWire::onRequest(void (*)())'
sketch\Wire.cpp.o:sketch/Wire.cpp:248: first defined here
libraries\Wire\Wire.cpp.o:(.bss.Wire+0x0): multiple definition of `Wire'
libraries\Wire\Wire.cpp.o:(.bss._ZN7TwoWire14user_onReceiveE+0x0): multiple definition of `TwoWire::user_onReceive'
libraries\Wire\Wire.cpp.o:(.bss._ZN7TwoWire14user_onRequestE+0x0): multiple definition of `TwoWire::user_onRequest'
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
[code]
//based on Basic ESP8266 MQTT example
#include <PubSubClient.h>
#include <Wire.h>
byte sleepTimeS = 5; // Deep sleep time in seconds
//For MPU650
const int MPU_addr = 0x68; // I2C address of the MPU-6050
int16_t AcX, AcY, AcZ, Tmp, GyX, GyY, GyZ, hold; // data
const char* pub1 = "Hydro/Pink/TILT" ; //send angle
const char* pub2 = "Hydro/Pink/TEMP" ; //send temperature
const char* sub1 = "Hydro/Pink/TARE" ; //recieve tare switch position
const char* sub2 = "Hydro/Pink/BATT" ; //recieve battery Saver Value
String keeper;
// Update these with values suitable for your network.
const char* ssid = "WLAN6f84C";
const char* password = "080DB6F84C";
const char* mqtt_server = "broker.mqttdashboard.com";// no :1883
WiFiClient espClient;
PubSubClient client(espClient);
long lastMsg = 0;
char msg[50]; //tilt
char msg2[50]; //temp
//char Tilt[10];
int Tilt = 0;
int calibrateValue = 0;
byte SwitchPos;
float KeepTime = 0;
String SetTime;
String message;
void setup_wifi() {
delay(10);
Serial.println(ssid);
WiFi.begin(ssid, password);
randomSeed(micros());
Serial.println("");
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
// Attempt to connect
Serial.print("Attempting MQTT connection...");
if (client.connect("ESP8266Client")) {
Serial.println("connected"); // Once connected, publish an announcement...
//Duplicate these as needed
client.publish(pub1, "0"); //Set up Publising for each value
client.publish(pub2, "0");
// ... and resubscribe
client.subscribe(sub1); //Set up Subscription for each value
client.subscribe(sub2);
} else {
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
//Wire.begin(2,0); //nodeMCU D2,D1 8622-01 2,0
Serial.println("Initializing I2C devices...");
//pinMode(BUILTIN_LED, OUTPUT); // Initialize the BUILTIN_LED pin as an output
setup_wifi();
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
Wire.beginTransmission(MPU_addr);
Wire.write(0x6B); // PWR_MGMT_1 register
Wire.write(0); // set to zero (wakes up the MPU-6050)
Wire.endTransmission(true);
if (!client.connected()) {
reconnect();
client.loop();
long now = millis();
if (now - lastMsg > 2000 + KeepTime) { //2 seconds as a buffer
lastMsg = now;
getTemp();
if (SwitchPos == 0) { // Implament Tare value
Tilt = Tilt - calibrateValue;
//Serial.println(" Switch 0 ");
//Serial.println (Tilt);
snprintf (msg, 75, "%ld", Tilt);
Serial.print("Tilt message: ");
Serial.println(msg);
client.publish(pub1, msg); // Publish Tilt
Serial.print("Temp message: ");
snprintf (msg2, 75, "%ld", Tmp);
client.publish(pub2, msg2); // Publish Temp
Serial.println(msg2);
delay(300);
void callback(String topic, byte* payload, unsigned int length) {
Serial.print("Message arrived [");
Serial.print(topic);
Serial.print("] ");
for (int i = 0; i < length; i++) { // Used to concatanate the message
message += (char)payload[i];
keeper = message; //Store the message
message = ""; //Clear the buffer
Serial.println(keeper); //debug chcek for data captured
if (topic == sub1) { //Tare Switch data
// Switch on the LED if an 1 was received as first character
if (keeper == "1") { //Tare Position
digitalWrite(BUILTIN_LED, LOW); // Turn the LED on (Note that LOW is the voltage level
// but actually the LED is on; this is because
// it is acive low on the ESP-01)
calibrateValue = Tilt; //Store data to find a zero point.
if (calibrateValue < 0) {
calibrateValue = 0;
SwitchPos = 1; //elimiate taring a tare value
Serial.print("calabrating");
if (keeper == "0") { //Tare Position
digitalWrite(BUILTIN_LED, HIGH); // Turn the LED off by making the voltage HIGH
SwitchPos = 0;
Serial.print(" callValue ");
Serial.println(calibrateValue);
if (topic == sub2) { // Battery Saver data
KeepTime = keeper.toInt();
KeepTime = KeepTime * 3600000; // scale microseconds to hours
Serial.print(" KeepTime = ");
Serial.println(KeepTime);
void getTemp(){
//int Tmp=0;
Wire.write(0x3B); // starting with register 0x3B (ACCEL_XOUT_H)
Wire.endTransmission(false);
Wire.requestFrom(MPU_addr, 14, true); // request a total of 14 registers
AcX = Wire.read() << 8 | Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
AcY = Wire.read() << 8 | Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
AcZ = Wire.read() << 8 | Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
Tmp = Wire.read() << 8 | Wire.read(); // 0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
GyX = Wire.read() << 8 | Wire.read(); // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
GyY = Wire.read() << 8 | Wire.read(); // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
GyZ = Wire.read() << 8 | Wire.read(); // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
//Tmp = Tmp / 340.00 + 33.6; //equation for temperature in degrees C from datasheet 340/36.53
//Tmp = Tmp * 1.8 + 32; //convert to F Comment out for C
Tilt = AcX / 100;
Serial.print("AcX = "); Serial.print(AcX / 100);
//Serial.print(" | AcY = "); Serial.print(AcY);
//Serial.print(" | AcZ = "); Serial.print(AcZ);
Serial.print(" | Tmp = "); Serial.println(Tmp);
// snprintf (msg, 75, "%ld", Tmp);
//client.publish(pub2, msg);//
delay(300);
Re: ESP8266 ESP-12E Problems with Wire.h & Wire.cpp
PostPosted: Wed Mar 15, 2017 9:03 am
by martinayotte
You seems to have multiple Wire libraries conflicting with the one from ESP.
Remove them from your sketch ...
PostPosted: Tue Mar 21, 2017 12:57 pm
by desmop
martinayotte wrote:You seems to have multiple Wire libraries conflicting with the one from ESP.
Dear Martinayotte,
Thank you for you help. I'm not sure what you mean when you say remove the libraries. Could you please explain in detail. I appreciate your help. :)
