By sfranzyshen
#9362
stephane95 wrote:Hi
I'm really insterrested by testing your firmware but i'm a noob :-(
I've falshed it, I've created a 15*16 neopixel led matrix (tested with arduino and work fine) for exemple with a wonderful software : Jinx! http://www.live-leds.de/
But can I have more explanation on running tpm2net ?
Like dat a are on GPIO 0 or 2, how can I set the module as AP or can it join my own network ?
I seeking for that kind of stuff since one year I create my matrix but without handy solution to manage it.
Thank in advance for you help.
Regards Stéphane
the setup is the same as outlined here https://github.com/cnlohr/ws2812esp8266 so hookup the di (data) of your lights to gpio0 and a 100p cap between gpio0 & ground. connect the ground of the esp & ground of you power supply for the lights together(do not connect +5v to the esp) ... the current firmware sets itself up as an AP with dhcp. there are no other options to connect and make changes ... yet! I have not tested this with jinx (curious to know if it works) ... either way ... setup your output to use tpm2net and point it to 192.168.4.1 ;)
By sfranzyshen
#9364
sfranzyshen wrote:
folny82 wrote:Hi
Great work program works perfectly, I want to add support for http configurable by example esphttpd but it throws me this error do not know where the problem may be ?.
try adding #include "ets_sys.h" to the ws2812.c file??
I am also looking at how to add a web interface to this ... but I thought the esphttpd might be a little over kill and does not support ssl. I am leaning to json (like the IoT_Demo) with one exception ... it will server up a javascript client app. I would still be interested in how you make out adding the to the esphttpd project ... let us know how you make out!
By sfranzyshen
#9365
sfranzyshen wrote:
sfranzyshen wrote:
folny82 wrote:Hi
I am also looking at how to add a web interface to this ... but I thought the esphttpd might be a little over kill and does not support ssl. I am leaning to json (like the IoT_Demo) with one exception ... it will server up a javascript client app. I would still be interested in knowing how you make out adding this to the esphttpd project ... let us know how it goes!
By folny82
#9367 Thank you for your answer but can you indicate precisely where I #include "ets_sys.h" add or remove ? So far as I learn to program esp chip. I still have one question the need to modify any library that I can control 512 LEDs I tried Jinx and Pixelcontroller but I managed to control a maximum of about 488 LEDs.
