Sorry that I can't replicate your problem ... I tested in station mode, it's fine..
The only difference between us is that my Apple Airport Espress is 7.6.5 .. Maybe you could try to update your router ?
Explore... Chat... Share...
The code you installed was likely meant for the ES[…]
Thanks a lot for sharing this project.
Yes, there are examples of connecting to an ESP826[…]
Using an ESP8266 to read the duty cycle of the sea[…]
Positioning the ESP-32 on top to dissipate heat is[…]
It sounds like the two Sonoff Basic devices you ar[…]
Some similar problems have been discussed in the f[…]
If you're facing issues with the anemometer, you c[…]
I understand that delay Microseconds might be clos[…]
It looks as though you are not passing enough para[…]
The issue is solved. 1) TTUSB0 is taken by BRLTTY […]
You have to install the <FirebaseESP8266.h> […]
I decided to use 3.2 V lifopo4 battery and discard[…]
An official web portal created by Kroger is called[…]
Follow US on Twitter and get ESP8266 news and updates first.
