By frjariello
#74507 Hi,
I made a small script to check when someone (smartphone) connects to my Esp in order to enable a command.
The problem is that when the smartphone goes away and loses the connection wifi_softap_get_station_num is not updated and still counts it as connected...
Is there any way to force an update?
Or at worst, is it possible to set a connection duration, so that after 2 minutes it disconnects the client?
Thanks
bye bye
By frjariello
#74788 my use is very simple, this is the code, which I partly took from a post on this forum
extern "C" {
#include<user_interface.h>
const char *ssid = "ssidWiFi";
const char *password = "password";
boolean Richiesta = false;
unsigned char connessioni = 0;
int D0 = 2;
int D4 = 16;
  pinMode(D4, OUTPUT);
  pinMode(D0, OUTPUT);
  system_phy_set_max_tpw(50);
  WiFi.softAP(ssid, password);
  WiFi.begin();
  Serial.println("");
  Serial.println("- - - WiFi Avviato - - -");
  delay(1000);
  client_status();
  delay(1000);
void client_status() {
    unsigned char number_client;
    struct station_info *stat_info;
    struct ip_addr *IPaddress;
    IPAddress address;
    number_client= wifi_softap_get_station_num();
    stat_info = wifi_softap_get_station_info();
    if (stat_info != NULL ) {
      IPaddress = &stat_info->ip;
      address = IPaddress->addr;
    if (connessioni < number_client) {
      Serial.println(millis()/1000);
      Serial.print(" Numero di connessioni = ");
      Serial.println(number_client);
      connessioni = number_client;
      Richiesta = true;
    if (stat_info != NULL && Richiesta) {
      Serial.print("- Indirizzo IP assegnato = ");
      Serial.println((address));
      Serial.print("- MAC Address = ");
      Serial.print(stat_info->bssid[0],HEX);
      Serial.print(stat_info->bssid[1],HEX);
      Serial.print(stat_info->bssid[2],HEX);
      Serial.print(stat_info->bssid[3],HEX);
      Serial.print(stat_info->bssid[4],HEX);
      Serial.print(stat_info->bssid[5],HEX);
      digitalWrite(D4, 1);
      Serial.println("- Led ACCESO");
      digitalWrite(D0, 1);
      Serial.println("- Comando ad ON");
      delay(1000);
      digitalWrite(D4, 0);
      Serial.println("- Led SPENTO");
      digitalWrite(D0, 0);
      Serial.println("- Comando ad OFF");
      Richiesta = false;
    else {
      if (number_client == 0) {
        Serial.println("- Nessuna Connessione");
        connessioni = 0;
But once connected, if I move away and the connection falls, the number of wifi_softap_get_station_num() does not change :(
bye bye
