I am using a esp lolin with an arducam ov2640 plus to take pictures and stream video- I have stted the router in order to be able to open the server of the esp in internet and so have access from any browser.
My first problem is that when I try to get streaming or picture without using the internal home wifi the random browser used is able to connect and get into the server routin but not streaming or picture while at home when browser use the same wifi line the esp uses every thing is showned correctly.
Second dilemma is that since i´ve flushed the esp module the arducam doesn´t store picture in his internal memory... I really wonder what the hell.. .. I serched but no idea.. this is my code:
// ESP8266-12E ArduCAM Mini Camera Server
// This program demonstrates using an ArduCAM Mini 2MP camera with an ESP8266-12E module.
// An OV2640 2MP ArduCAM Mini was used with this program.
// The program has a web interface that will allow:
// - storing and viewing of captured jpg files
// - viewing live streamed video
// - changing the resolution
// Captured jpeg files are stored on the ESP8266-12E built in memory.
// The capture and streaming features can be reached directly via the browser by using the format:
// http://IPaddress/capture - for still capture
// http://IPaddress/stream - for streaming video
// The captured stills or streamed video can be accessed as an HTML image:
// <img src="http://IPaddress/capture">
// or
// <img src="http://IPaddress/stream">
// Wiring diagram to connect ArduCAM to ESP8266-12E
// ArduCAM mini -> ESP8266-12E
// CS -> D0
// MOSI -> D7
// MISC -> D6
// SCK -> D5
// GND -> GND
// VCC -> 3V3
// SDA -> D2
// SCL -> D1
#include <FS.h> // FOR SPIFFS
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <Wire.h>
#include <ArduCAM.h>
#include <SPI.h>
#include "memorysaver.h"
#if !(defined ESP8266 )
#error Please select the ArduCAM ESP8266 UNO board in the Tools/Board
#endif
//This demo can only work on OV2640_MINI_2MP or ARDUCAM_SHIELD_V2 platform.
#if !(defined OV2640_MINI_2MP_PLUS)
#error Please select the hardware platform and camera module in the ../libraries/ArduCAM/memorysaver.h file
#endif
// set GPIO16 as the slave select :
const int CS = D0;//16;
// if the video is chopped or distored, try using a lower value for the buffer
// lower values will have fewer frames per second while streaming
static const size_t bufferSize = 2048; // 4096; //2048; //1024;
static const int fileSpaceOffset = 700000;
static const int wifiType = 0; // 0:Station 1:AP
//AP mode configuration
const char *AP_ssid = "arducam_esp8266";
//Default is no password.If you want to set password,put your password here
const char *AP_password = "APpassword";
//Station mode you should put your ssid and password
const char *ssid = "myssid"; // Put your SSID here
const char *password = "mypassword"; // Put your PASSWORD here
static IPAddress ip(192, 168, 178, 177); // static IP used for browser access: http://IPaddress
static IPAddress gateway(192, 168, 178, 1);
static IPAddress subnet(255, 255, 255, 0);
IPAddress ip(192, 168, 178, 177); // where xx is the desired IP Address
IPAddress gateway(192, 168, 178, 1); // set gateway to match your network
Serial.print(F("Setting static ip to : 192,168,178,177"));
//Serial.println(ip);
IPAddress subnet(255, 255, 255, 0); // set subnet mask to match your network
//WiFi.config(ip, gateway, subnet);
const String fName = "res.txt";
int fileTotalKB = 0;
int fileUsedKB = 0;
int fileCount = 0;
String errMsg = "";
int imgMode = 1; // 0: stream 1: capture
int resolution = 3;
// resolutions:
// 0 = 160x120
// 1 = 176x144
// 2 = 320x240
// 3 = 352x288
// 4 = 640x480
// 5 = 800x600
// 6 = 1024x768
// 7 = 1280x1024
// 8 = 1600x1200
ESP8266WebServer server(80);
ArduCAM myCAM(OV2640, CS);
// Updates Properties file with resolution ///
void updateDataFile()
File f = SPIFFS.open(fName, "w");
if (!f) {
Serial.println("prop file open failed");
Serial.println("====== Writing to prop file =========");
f.println(resolution);
Serial.println("Data file updated");
f.close();
// Saves captured image to memory //
void myCAMSaveToSPIFFS() {
// as file space is used, capturing images will get slower. At a certain point, the images will become distored
// or they will not save at all due to lack of space. To avoid this we set a limit and allow some free space to remain
if ((fileTotalKB - fileUsedKB) < fileSpaceOffset)
String maxStr = "====== Maximum Data Storage Reached =========";
Serial.println(maxStr);
errMsg = maxStr;
return;
String str;
byte buf[256];
static int i = 0;
static int n = 0;
uint8_t temp, temp_last;
// File file;
//Flush the FIFO
myCAM.flush_fifo();
//Clear the capture done flag
myCAM.clear_fifo_flag();
//Start capture
myCAM.start_capture();
while (!myCAM.get_bit(ARDUCHIP_TRIG , CAP_DONE_MASK));
Serial.println("File Capture Done!");
fileCount++;
str = "/pics/" + String(fileCount) + ".jpg";
File f = SPIFFS.open(str, "w");
if (!f) {
Serial.println(str);
i = 0;
myCAM.CS_LOW();
myCAM.set_fifo_burst();
#if !(defined (OV2640_MINI_2MP_PLUS))
SPI.transfer(0xFF);
#endif
//Read JPEG data from FIFO
while ( (temp != 0xD9) | (temp_last != 0xFF)) {
temp_last = temp;
temp = SPI.transfer(0x00);
//Write image data to buffer if not full
if ( i < 256)
buf[i++] = temp;
else {
//Write 256 bytes image data to file
myCAM.CS_HIGH();
f.write(buf , 256);
i = 0;
buf[i++] = temp;
myCAM.CS_LOW();
//delay(0);
//Write the remain bytes in the buffer
if (i > 0) {
myCAM.CS_HIGH();
f.write(buf, i);
//Close the file
f.close();
Serial.println("CAM Save Done!");
// Retrieves a stored jpg file and sends to browser based on url: http://IPaddress/1.jpg //
bool loadFromSpiffs(String path) {
String dataType = "text/plain";
if (path.endsWith("/")) path += "index.htm";
if (path.endsWith(".src")) path = path.substring(0, path.lastIndexOf("."));
// else if (path.endsWith(".htm")) dataType = "text/html";
// else if (path.endsWith(".css")) dataType = "text/css";
// else if (path.endsWith(".js")) dataType = "application/javascript";
// else if (path.endsWith(".png")) dataType = "image/png";
// else if (path.endsWith(".gif")) dataType = "image/gif";
else if (path.endsWith(".jpg")) dataType = "image/jpeg";
// else if (path.endsWith(".ico")) dataType = "image/x-icon";
// else if (path.endsWith(".xml")) dataType = "text/xml";
// else if (path.endsWith(".pdf")) dataType = "application/pdf";
// else if (path.endsWith(".zip")) dataType = "application/zip";
File dataFile = SPIFFS.open(path.c_str(), "r");
if (server.hasArg("download")) dataType = "application/octet-stream";
if (server.streamFile(dataFile, dataType) != dataFile.size()) {
dataFile.close();
return true;
// sets the HTML used for the resoultions drop down //
String getDropDown()
String webString = "";
webString += "<select name=\"rez\">\n";
webString += " <option value=\"0\" ";
if (resolution == 0)
webString += " selected=\"seleted\" ";
webString += ">160x120</option>\n";
webString += " <option value=\"1\" ";
if (resolution == 1)
webString += ">176x144</option>\n";
webString += " <option value=\"2\" ";
if (resolution == 2)
webString += ">320x240</option>\n";
webString += " <option value=\"3\" ";
if (resolution == 3)
webString += ">352x288</option>\n";
webString += " <option value=\"4\" ";
if (resolution == 4)
webString += ">640x480</option>\n";
webString += " <option value=\"5\" ";
if (resolution == 5)
webString += ">800x600</option>\n";
webString += " <option value=\"6\" ";
if (resolution == 6)
webString += ">1024x768</option>\n";
webString += " <option value=\"7\" ";
if (resolution == 7)
webString += ">1280x1024</option>\n";
webString += " <option value=\"8\" ";
if (resolution == 8)
webString += ">1600x1200</option>\n";
webString += " </select>\n";
return webString;
// capture initialization //
void start_capture() {
// capture still image and send to client //
void camCapture(ArduCAM myCAM) {
WiFiClient client = server.client();
size_t len = myCAM.read_fifo_length();
if (len >= 0x07ffff) {
Serial.println("Over size.");
return;
} else if (len == 0 ) {
Serial.println("Size is 0.");
return;
myCAM.CS_LOW();
SPI.transfer(0xFF);
#endif
if (!client.connected()) return;
String response = "HTTP/1.1 200 OK\r\n";
response += "Content-Type: image/jpeg\r\n";
response += "Content-Length: " + String(len) + "\r\n\r\n";
server.sendContent(response);
static uint8_t buffer[bufferSize] = {0xFF};
while (len) {
size_t will_copy = (len < bufferSize) ? len : bufferSize;
SPI.transferBytes(&buffer[0], &buffer[0], will_copy);
if (!client.connected()) break;
client.write(&buffer[0], will_copy);
len -= will_copy;
myCAM.CS_HIGH();
// initiate capture and record time used //
void serverCapture() {
start_capture();
Serial.println("CAM Capturing");
int total_time = 0;
total_time = millis();
while (!myCAM.get_bit(ARDUCHIP_TRIG, CAP_DONE_MASK));
total_time = millis() - total_time;
Serial.print("capture total_time used (in miliseconds):");
Serial.println(total_time, DEC);
total_time = 0;
Serial.println("CAM Capture Done!");
camCapture(myCAM);
Serial.print("send total_time used (in miliseconds):");
Serial.println("CAM send Done!");
// stream video to client //
void serverStream() {
response += "Content-Type: multipart/x-mixed-replace; boundary=frame\r\n\r\n";
while (client.connected()) {
start_capture();
continue;
continue;
myCAM.CS_LOW();
SPI.transfer(0xFF);
#endif
response = "--frame\r\n";
response += "Content-Type: image/jpeg\r\n\r\n";
while (len) {
len -= will_copy;
myCAM.CS_HIGH();
// Default web handler used when client access web server //
void handleNotFound() {
String ipStr = WiFi.localIP().toString();
if (wifiType == 1) // AP mode = 1
ipStr = WiFi.softAPIP().toString();
Serial.print("server uri: " ); Serial.println(server.uri());
// if url contains request for stored image: http://IPaddress/pics/2.jpg
if (server.uri().indexOf(".jpg") != -1 )
loadFromSpiffs(server.uri());
return;
//// default HTML
String message = "<html><head>\n";
message += "</head><body>\n";
message += "<form action=\"http://" + ipStr + "/submit\" method=\"POST\">";
message += "<h1>MY GARDEN</h1>\n";
if (errMsg != "")
message += "<div style=\"color:red\">" + errMsg + "</div>";
if (imgMode == 0) // stream mode
message += "<div><h2>Video Streaming</h2></div> \n";
message += "<div><img id=\"ArduCam\" src=\"http://" + ipStr + "/stream\" ></div>\n";
imgMode = 1; // set back to capture mode so it doesn't get stuck in streaming mode
message += "<div>";
message += getDropDown();
message += " <input type=\"radio\" id=\"strm\" name=\"imgMode\" value=\"stream\" ";
if (imgMode == 0)
message += " checked ";
message += "> Stream \n";
message += " <input type=\"radio\" id=\"capt\" name=\"imgMode\" value=\"capture\" ";
if (imgMode == 1)
message += "> Capture \n";
message += " <input type='submit' value='Submit' >\n";
message += " <a style=\"font-size:12px; font-weight:bold;\" href=\"http://" + ipStr + "\">Refresh</a>";
message += " <a style=\"font-size:12px; font-weight:bold;\" onclick=\"return confirm('Are you sure? This will delete all stored images.')\" ";
message += " href=\"http://" + ipStr + "/clear\">Clear Data</a>\n";
message += "</div>\n";
FSInfo fs_info;
SPIFFS.info(fs_info);
fileTotalKB = (int)fs_info.totalBytes;
fileUsedKB = (int)fs_info.usedBytes;
if (fileCount > 0)
int percentUsed = ((float)fileUsedKB / (float)(fileTotalKB - fileSpaceOffset)) * 100;
String colorStr = "green";
if (percentUsed > 90)
colorStr = "red";
message += "<div style=\"width:450px; background-color:darkgray; padding:1px;\">";
message += "<div style=\"position:absolute; color:white; padding-top:2px; font-size:11px;\"> space used: " + String(percentUsed) + "%</div>";
message += "<div style=\"width:" + String(percentUsed) + "%; height:16px; background-color: " + colorStr + ";\"></div></div>\n";
message += "<table><tr>";
int colCnt = 0;
for (int i = 1; i <= fileCount; i++)
message += "<td><a href=\"/pics/" + String(i) + ".jpg\">" + i + ".jpg</a></td>\n";
colCnt++;
if (colCnt >= 10) // columns
message += "</tr><tr>";
colCnt = 0;
message += "</tr></table>\n";
//useful for debugging max data storage
message += "<table><tr><td>Total Bytes: </td><td style=\"text-align:right;\">";
message += fileTotalKB;
message += "</td></tr><tr><td>Used Bytes: </td><td style=\"text-align:right;\">";
message += fileUsedKB;
message += "</td></tr><tr><td>Remaing Bytes: </td><td style=\"text-align:right;\">";
message += (fileTotalKB - fileUsedKB);
message += "</td></tr></table>\n";
float flashChipSize = (float)ESP.getFlashChipSize() / 1024.0 / 1024.0;
message += "<br>chipSize: ";
message += flashChipSize;
message += "<div><img id=\"ArduCam\" src=\"http://" + ipStr + "/capture\" ></div>\n";
message += "</form> \n";
message += "</body></html>\n";
server.send(200, "text/html", message);
// used when form is submitted and at setup to set the camera resolution //
void setCamResolution(int reso)
switch (reso)
case 0:
myCAM.OV2640_set_JPEG_size(OV2640_160x120);
resolution = 0;
break;
case 1:
myCAM.OV2640_set_JPEG_size(OV2640_176x144);
resolution = 1;
break;
case 2:
myCAM.OV2640_set_JPEG_size(OV2640_320x240);
resolution = 2;
break;
case 3:
myCAM.OV2640_set_JPEG_size(OV2640_352x288);
resolution = 3;
break;
case 4:
myCAM.OV2640_set_JPEG_size(OV2640_640x480);
resolution = 4;
break;
case 5:
myCAM.OV2640_set_JPEG_size(OV2640_800x600);
resolution = 5;
break;
case 6:
myCAM.OV2640_set_JPEG_size(OV2640_1024x768);
resolution = 6;
break;
case 7:
myCAM.OV2640_set_JPEG_size(OV2640_1280x1024);
resolution = 7;
break;
case 8:
myCAM.OV2640_set_JPEG_size(OV2640_1600x1200);
resolution = 8;
break;
// deletes all files in the /pics directory //
void clearData()
errMsg = "====== Data Storage Cleared =========";
Dir dir = SPIFFS.openDir("/pics");
while (dir.next()) {
SPIFFS.remove(dir.fileName());
fileCount = 0;
fileTotalKB = 0;
fileUsedKB = 0;
handleNotFound();
// handles form submission //
void handleSubmit()
errMsg = "";
Serial.println( "--- Form Submited ---");
Serial.println( "Server args " + server.args());
if (server.args() > 0 ) {
for ( uint8_t i = 0; i < server.args(); i++ ) {
// can be useful to determine the values from a form post.
Serial.println( "Server arg " + server.arg(i));
Serial.println( "Server argName " + server.argName(i) );
if (server.argName(i) == "imgMode")
Serial.println(" Image Mode: " + server.arg(i));
if (server.arg(i) == "stream")
imgMode = 0;
imgMode = 1; // capture mode
if (server.argName(i) == "rez") {
if (server.arg(i).toInt() != resolution)
setCamResolution(server.arg(i).toInt());
updateDataFile();
//// IMPORTANT: removing or reducing the delay can result in dark images
delay(1500); // add a delay to allow the white balance to adjust to new resolution
if (imgMode == 1) // capture
myCAMSaveToSPIFFS();
handleNotFound();
// main setup function //
SPIFFS.begin();
delay(10);
// SPIFFS.format(); // uncomment to completely clear data including properties file
// check for properties file
File f = SPIFFS.open(fName, "r");
if (!f) {
// no file exists so lets format and create a properties file
Serial.println("Please wait 30 secs for SPIFFS to be formatted");
SPIFFS.format();
Serial.println("Spiffs formatted");
if (!f) {
Serial.println("properties file open failed");
// write the defaults to the properties file
Serial.println("====== Writing to properties file =========");
f.close();
// if the properties file exists on startup, read it and set the defaults
Serial.println("Properties file exists. Reading.");
while (f.available()) {
// read line by line from the file
String str = f.readStringUntil('\n');
resolution = str.toInt();
f.close();
uint8_t vid, pid;
uint8_t temp;
#if defined(__SAM3X8E__)
Wire1.begin();
#else
Wire.begin();
#endif
Serial.println("ArduCAM Start!");
// set the CS as an output:
pinMode(CS, OUTPUT);
// initialize SPI:
SPI.begin();
SPI.setFrequency(4000000); //4MHz
//Check if the ArduCAM SPI bus is OK
myCAM.write_reg(ARDUCHIP_TEST1, 0x55);
temp = myCAM.read_reg(ARDUCHIP_TEST1);
if (temp != 0x55) {
Serial.println("SPI1 interface Error!");
//Check if the camera module type is OV2640
myCAM.wrSensorReg8_8(0xff, 0x01);
myCAM.rdSensorReg8_8(OV2640_CHIPID_HIGH, &vid);
myCAM.rdSensorReg8_8(OV2640_CHIPID_LOW, &pid);
if ((vid != 0x26 ) && (( pid != 0x41 ) || ( pid != 0x42 )))
Serial.println("Can't find OV2640 module! pid: " + String(pid));
Serial.println("OV2640 detected.");
//Change to JPEG capture mode and initialize the OV2640 module
myCAM.set_format(JPEG);
myCAM.InitCAM();
setCamResolution(resolution);
if (wifiType == 0) {
if (!strcmp(ssid, "SSID")) {
Serial.println("my ssid");
if (!strcmp(password, "PASSWORD")) {
Serial.println("my password");
// Connect to WiFi network
Serial.println(ssid);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
Serial.print(".");
// WiFi.config(ip, gateway, subnet); // remove this line to use DHCP questa la linea che faceva conflitto
Serial.println("");
Serial.print("ip: ");
} else if (wifiType == 1) {
Serial.print("Share AP: ");
Serial.println(AP_ssid);
Serial.print("The password is: ");
Serial.println(AP_password);
WiFi.mode(WIFI_AP);
WiFi.softAP(AP_ssid, AP_password);
Serial.println("");
Serial.println("AP ip");
Serial.println(WiFi.softAPIP());
// setup handlers
server.on("/capture", HTTP_GET, serverCapture);
server.on("/stream", HTTP_GET, serverStream);
server.on("/submit", handleSubmit);
server.on("/clear", clearData);
server.onNotFound(handleNotFound);
server.begin();
fileCount++;
FSInfo fs_info;
// Main loop function //
server.handleClient();
I really appreciate your help!
