Page 1 of 6
ESP8266 01 Reset
PostPosted: Mon Apr 09, 2018 1:05 pm
by Giants
Hello
first i hope i'm in the right room. Are many day i became crazy with this problem, i wrote one simple program with eclipse just send Hello Word on UAR0 it works but after a while i receive this message
est Jan 8 2013,rst cause:2, boot mode:(3,7). The power supply it's correct
i have the 2.0.0 SDK from espressif
Please someone can help me :roll: :roll: :roll: :roll: :roll:
Thank you
Sergio
Re: ESP8266 01 Reset
PostPosted: Mon Apr 09, 2018 7:56 pm
by rudy
Post your code so we can see if you did anything wrong.
I have heard that many times before, and it was often not true.
PostPosted: Tue Apr 10, 2018 1:38 pm
by Giants
Thanks for your answer. I post the code i wrote (and in part copy) :
#include <ets_sys.h>
#include <user_interface.h>
#include <osapi.h>
#include <c_types.h>
#include "uart.h"
//extern void ets_wdt_enable (void);
//extern void ets_wdt_disable (void);
* FunctionName : user_rf_cal_sector_set
* Description : SDK just reversed 4 sectors, used for rf init data and paramters.
* We add this function to force users to set rf cal sector, since
* we don't know which sector is free in user's application.
* sector map for last several sectors : ABBBCDDD
* A : rf cal
* B : at parameters
* C : rf init data
* D : sdk parameters
* Parameters : none
* Returns : rf cal sector
uint32 user_rf_cal_sector_set(void)
enum flash_size_map size_map = system_get_flash_size_map();
uint32 rf_cal_sec = 0;
switch (size_map) {
case FLASH_SIZE_4M_MAP_256_256:
rf_cal_sec = 128 - 8;
break;
case FLASH_SIZE_8M_MAP_512_512:
rf_cal_sec = 256 - 5;
break;
case FLASH_SIZE_16M_MAP_512_512:
case FLASH_SIZE_16M_MAP_1024_1024:
rf_cal_sec = 512 - 5;
break;
case FLASH_SIZE_32M_MAP_512_512:
case FLASH_SIZE_32M_MAP_1024_1024:
rf_cal_sec = 1024 - 5;
break;
default:
rf_cal_sec = 0;
break;
return rf_cal_sec;
void user_init(void)
ets_wdt_enable();
ets_wdt_disable();
gpio_init();
UART_ResetFifo(UART0);
UART_SetBaudrate(UART0,115200);
UART_SetWordLength(UART0, 0x3);
UART_SetParity(UART0, 0x2);
UART_SetStopBits(UART0, 0x1);
for(;;)
os_delay_us(100000);
uart0_sendStr(" Hello Word \n\r ");
Why you told me : "I have heard that many times before, and it was often not true." i give 3.3V i did something wrong ?
i send the uart.h i you see there is part.c together because i had trouble whit eclipse but about that i wrote another time
* File : uart.h
* Copyright (C) 2013 - 2016, Espressif Systems
* This program is free software: you can redistribute it and/or modify
* it under the terms of version 3 of the GNU General Public License as
* published by the Free Software Foundation.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License along
* with this program. If not, see <http://www.gnu.org/licenses/>.
#ifndef UART_APP_H
#define UART_APP_H
#include "uart_register.h"
#include "eagle_soc.h"
#include "c_types.h"
#define UART_TX_BUFFER_SIZE 256 //Ring buffer length of tx buffer
#define UART_RX_BUFFER_SIZE 256 //Ring buffer length of rx buffer
#define UART_BUFF_EN 0 //use uart buffer , FOR UART0
#define UART_SELFTEST 0 //set 1:enable the loop test demo for uart buffer, FOR UART0
#define UART_HW_RTS 0 //set 1: enable uart hw flow control RTS, PIN MTDO, FOR UART0
#define UART_HW_CTS 0 //set1: enable uart hw flow contrl CTS , PIN MTCK, FOR UART0
#define UART0 0
#define UART1 1
typedef enum {
FIVE_BITS = 0x0,
SIX_BITS = 0x1,
SEVEN_BITS = 0x2,
EIGHT_BITS = 0x3
} UartBitsNum4Char;
typedef enum {
ONE_STOP_BIT = 0x1,
ONE_HALF_STOP_BIT = 0x2,
TWO_STOP_BIT = 0x3
} UartStopBitsNum;
typedef enum {
NONE_BITS = 0x2,
ODD_BITS = 1,
EVEN_BITS = 0
} UartParityMode;
typedef enum {
STICK_PARITY_DIS = 0,
STICK_PARITY_EN = 1
} UartExistParity;
typedef enum {
UART_None_Inverse = 0x0,
UART_Rxd_Inverse = UART_RXD_INV,
UART_CTS_Inverse = UART_CTS_INV,
UART_Txd_Inverse = UART_TXD_INV,
UART_RTS_Inverse = UART_RTS_INV,
} UART_LineLevelInverse;
typedef enum {
BIT_RATE_300 = 300,
BIT_RATE_600 = 600,
BIT_RATE_1200 = 1200,
BIT_RATE_2400 = 2400,
BIT_RATE_4800 = 4800,
BIT_RATE_9600 = 9600,
BIT_RATE_19200 = 19200,
BIT_RATE_38400 = 38400,
BIT_RATE_57600 = 57600,
BIT_RATE_74880 = 74880,
BIT_RATE_115200 = 115200,
BIT_RATE_230400 = 230400,
BIT_RATE_460800 = 460800,
BIT_RATE_921600 = 921600,
BIT_RATE_1843200 = 1843200,
BIT_RATE_3686400 = 3686400,
} UartBautRate;
typedef enum {
NONE_CTRL,
HARDWARE_CTRL,
XON_XOFF_CTRL
} UartFlowCtrl;
typedef enum {
USART_HardwareFlowControl_None = 0x0,
USART_HardwareFlowControl_RTS = 0x1,
USART_HardwareFlowControl_CTS = 0x2,
USART_HardwareFlowControl_CTS_RTS = 0x3
} UART_HwFlowCtrl;
typedef enum {
EMPTY,
UNDER_WRITE,
WRITE_OVER
} RcvMsgBuffState;
typedef struct {
uint32 RcvBuffSize;
uint8 *pRcvMsgBuff;
uint8 *pWritePos;
uint8 *pReadPos;
uint8 TrigLvl; //JLU: may need to pad
RcvMsgBuffState BuffState;
} RcvMsgBuff;
typedef struct {
uint32 TrxBuffSize;
uint8 *pTrxBuff;
} TrxMsgBuff;
typedef enum {
BAUD_RATE_DET,
WAIT_SYNC_FRM,
SRCH_MSG_HEAD,
RCV_MSG_BODY,
RCV_ESC_CHAR,
} RcvMsgState;
typedef struct {
UartBautRate baut_rate;
UartBitsNum4Char data_bits;
UartExistParity exist_parity;
UartParityMode parity;
UartStopBitsNum stop_bits;
UartFlowCtrl flow_ctrl;
RcvMsgBuff rcv_buff;
TrxMsgBuff trx_buff;
RcvMsgState rcv_state;
int received;
int buff_uart_no; //indicate which uart use tx/rx buffer
} UartDevice;
void uart_init(UartBautRate uart0_br, UartBautRate uart1_br);
void uart0_sendStr(const char *str);
#define UART_FIFO_LEN 128 //define the tx fifo length
#define UART_TX_EMPTY_THRESH_VAL 0x10
struct UartBuffer{
uint32 UartBuffSize;
uint8 *pUartBuff;
uint8 *pInPos;
uint8 *pOutPos;
STATUS BuffState;
uint16 Space; //remanent space of the buffer
uint8 TcpControl;
struct UartBuffer * nextBuff;
struct UartRxBuff{
uint32 UartRxBuffSize;
uint8 *pUartRxBuff;
uint8 *pWritePos;
uint8 *pReadPos;
STATUS RxBuffState;
uint32 Space; //remanent space of the buffer
typedef enum {
RUN = 0,
BLOCK = 1,
} TCPState;
//void ICACHE_FLASH_ATTR uart_test_rx();
STATUS uart_tx_one_char(uint8 uart, uint8 TxChar);
STATUS uart_tx_one_char_no_wait(uint8 uart, uint8 TxChar);
void uart1_sendStr_no_wait(const char *str);
struct UartBuffer* Uart_Buf_Init();
#if UART_BUFF_EN
LOCAL void Uart_Buf_Cpy(struct UartBuffer* pCur, char* pdata , uint16 data_len);
void uart_buf_free(struct UartBuffer* pBuff);
void tx_buff_enq(char* pdata, uint16 data_len );
LOCAL void tx_fifo_insert(struct UartBuffer* pTxBuff, uint8 data_len, uint8 uart_no);
void tx_start_uart_buffer(uint8 uart_no);
uint16 rx_buff_deq(char* pdata, uint16 data_len );
void Uart_rx_buff_enq();
#endif
void uart_rx_intr_enable(uint8 uart_no);
void uart_rx_intr_disable(uint8 uart_no);
void uart0_tx_buffer(uint8 *buf, uint16 len);
#define FUNC_UART0_CTS 4
#define FUNC_U0CTS 4
#define FUNC_U1TXD_BK 2
#define UART_LINE_INV_MASK (0x3f<<19)
void UART_SetWordLength(uint8 uart_no, UartBitsNum4Char len);
void UART_SetStopBits(uint8 uart_no, UartStopBitsNum bit_num);
void UART_SetLineInverse(uint8 uart_no, UART_LineLevelInverse inverse_mask);
void UART_SetParity(uint8 uart_no, UartParityMode Parity_mode);
void UART_SetBaudrate(uint8 uart_no,uint32 baud_rate);
void UART_SetFlowCtrl(uint8 uart_no,UART_HwFlowCtrl flow_ctrl,uint8 rx_thresh);
void UART_WaitTxFifoEmpty(uint8 uart_no , uint32 time_out_us); //do not use if tx flow control enabled
void UART_ResetFifo(uint8 uart_no);
void UART_ClearIntrStatus(uint8 uart_no,uint32 clr_mask);
void UART_SetIntrEna(uint8 uart_no,uint32 ena_mask);
void UART_SetPrintPort(uint8 uart_no);
bool UART_CheckOutputFinished(uint8 uart_no, uint32 time_out_us);
#endif
* File : uart.c
#include "ets_sys.h"
#include "osapi.h"
//#include "uart.h"
#include "osapi.h"
#include "mem.h"
#include "os_type.h"
// UartDev is defined and initialized in rom code.
extern UartDevice UartDev;
LOCAL struct UartBuffer* pTxBuffer = NULL;
LOCAL struct UartBuffer* pRxBuffer = NULL;
/*uart demo with a system task, to output what uart receives*/
/*this is a example to process uart data from task,please change the priority to fit your application task if exists*/
/*it might conflict with your task, if so,please arrange the priority of different task, or combine it to a different event in the same task. */
#define uart_recvTaskPrio 0
#define uart_recvTaskQueueLen 10
os_event_t uart_recvTaskQueue[uart_recvTaskQueueLen];
#define DBG
#define DBG1 uart1_sendStr_no_wait
#define DBG2 os_printf
LOCAL void uart0_rx_intr_handler(void *para);
* FunctionName : uart_config
* Description : Internal used function
* UART0 used for data TX/RX, RX buffer size is 0x100, interrupt enabled
* UART1 just used for debug output
* Parameters : uart_no, use UART0 or UART1 defined ahead
* Returns : NONE
LOCAL void ICACHE_FLASH_ATTR
uart_config(uint8 uart_no)
if (uart_no == UART1){
PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO2_U, FUNC_U1TXD_BK);
}else{
/* rcv_buff size if 0x100 */
ETS_UART_INTR_ATTACH(uart0_rx_intr_handler, &(UartDev.rcv_buff));
PIN_PULLUP_DIS(PERIPHS_IO_MUX_U0TXD_U);
PIN_FUNC_SELECT(PERIPHS_IO_MUX_U0TXD_U, FUNC_U0TXD);
#if UART_HW_RTS
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTDO_U, FUNC_U0RTS); //HW FLOW CONTROL RTS PIN
#endif
#if UART_HW_CTS
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTCK_U, FUNC_U0CTS); //HW FLOW CONTROL CTS PIN
#endif
uart_div_modify(uart_no, UART_CLK_FREQ / (UartDev.baut_rate));//SET BAUDRATE
WRITE_PERI_REG(UART_CONF0(uart_no), ((UartDev.exist_parity & UART_PARITY_EN_M) << UART_PARITY_EN_S) //SET BIT AND PARITY MODE
| ((UartDev.parity & UART_PARITY_M) <<UART_PARITY_S )
| ((UartDev.stop_bits & UART_STOP_BIT_NUM) << UART_STOP_BIT_NUM_S)
| ((UartDev.data_bits & UART_BIT_NUM) << UART_BIT_NUM_S));
//clear rx and tx fifo,not ready
SET_PERI_REG_MASK(UART_CONF0(uart_no), UART_RXFIFO_RST | UART_TXFIFO_RST); //RESET FIFO
CLEAR_PERI_REG_MASK(UART_CONF0(uart_no), UART_RXFIFO_RST | UART_TXFIFO_RST);
if (uart_no == UART0){
//set rx fifo trigger
WRITE_PERI_REG(UART_CONF1(uart_no),
((100 & UART_RXFIFO_FULL_THRHD) << UART_RXFIFO_FULL_THRHD_S) |
#if UART_HW_RTS
((110 & UART_RX_FLOW_THRHD) << UART_RX_FLOW_THRHD_S) |
UART_RX_FLOW_EN | //enbale rx flow control
#endif
(0x02 & UART_RX_TOUT_THRHD) << UART_RX_TOUT_THRHD_S |
UART_RX_TOUT_EN|
((0x10 & UART_TXFIFO_EMPTY_THRHD)<<UART_TXFIFO_EMPTY_THRHD_S));//wjl
#if UART_HW_CTS
SET_PERI_REG_MASK( UART_CONF0(uart_no),UART_TX_FLOW_EN); //add this sentense to add a tx flow control via MTCK( CTS )
#endif
SET_PERI_REG_MASK(UART_INT_ENA(uart_no), UART_RXFIFO_TOUT_INT_ENA |UART_FRM_ERR_INT_ENA);
}else{
WRITE_PERI_REG(UART_CONF1(uart_no),((UartDev.rcv_buff.TrigLvl & UART_RXFIFO_FULL_THRHD) << UART_RXFIFO_FULL_THRHD_S));//TrigLvl default val == 1
//clear all interrupt
WRITE_PERI_REG(UART_INT_CLR(uart_no), 0xffff);
//enable rx_interrupt
SET_PERI_REG_MASK(UART_INT_ENA(uart_no), UART_RXFIFO_FULL_INT_ENA|UART_RXFIFO_OVF_INT_ENA);
* FunctionName : uart1_tx_one_char
* Use uart1 interface to transfer one char
* Parameters : uint8 TxChar - character to tx
* Returns : OK
while (true){
uint32 fifo_cnt = READ_PERI_REG(UART_STATUS(uart)) & (UART_TXFIFO_CNT<<UART_TXFIFO_CNT_S);
if ((fifo_cnt >> UART_TXFIFO_CNT_S & UART_TXFIFO_CNT) < 126) {
break;
WRITE_PERI_REG(UART_FIFO(uart) , TxChar);
return OK;
* FunctionName : uart1_write_char
* Do some special deal while tx char is '\r' or '\n'
* Parameters : char c - character to tx
* Returns : NONE
uart1_write_char(char c)
if (c == '\n'){
uart_tx_one_char(UART1, '\r');
uart_tx_one_char(UART1, '\n');
}else if (c == '\r'){
}else{
uart_tx_one_char(UART1, c);
//os_printf output to fifo or to the tx buffer
uart0_write_char_no_wait(char c)
#if UART_BUFF_EN //send to uart0 fifo but do not wait
uint8 chr;
if (c == '\n'){
chr = '\r';
tx_buff_enq(&chr, 1);
chr = '\n';
}else{
tx_buff_enq(&c,1);
#else //send to uart tx buffer
if (c == '\n'){
uart_tx_one_char_no_wait(UART0, '\r');
uart_tx_one_char_no_wait(UART0, '\n');
else{
uart_tx_one_char_no_wait(UART0, c);
#endif
* FunctionName : uart0_tx_buffer
* Description : use uart0 to transfer buffer
* Parameters : uint8 *buf - point to send buffer
* uint16 len - buffer len
* Returns :
uint16 i;
for (i = 0; i < len; i++)
uart_tx_one_char(UART0, buf[i]);
* FunctionName : uart0_sendStr
* Returns :
while(*str){
uart_tx_one_char(UART0, *str++);
void at_port_print(const char *str) __attribute__((alias("uart0_sendStr")));
* FunctionName : uart0_rx_intr_handler
* UART0 interrupt handler, add self handle code inside
* Parameters : void *para - point to ETS_UART_INTR_ATTACH's arg
* Returns : NONE
LOCAL void
/* uart0 and uart1 intr combine togther, when interrupt occur, see reg 0x3ff20020, bit2, bit0 represents
* uart1 and uart0 respectively
uint8 RcvChar;
uint8 uart_no = UART0;//UartDev.buff_uart_no;
uint8 fifo_len = 0;
uint8 buf_idx = 0;
uint8 temp,cnt;
//RcvMsgBuff *pRxBuff = (RcvMsgBuff *)para;
/*ATTENTION:*/
/*IN NON-OS VERSION SDK, DO NOT USE "ICACHE_FLASH_ATTR" FUNCTIONS IN THE WHOLE HANDLER PROCESS*/
/*ALL THE FUNCTIONS CALLED IN INTERRUPT HANDLER MUST BE DECLARED IN RAM */
/*IF NOT , POST AN EVENT AND PROCESS IN SYSTEM TASK */
if(UART_FRM_ERR_INT_ST == (READ_PERI_REG(UART_INT_ST(uart_no)) & UART_FRM_ERR_INT_ST)){
DBG1("FRM_ERR\r\n");
WRITE_PERI_REG(UART_INT_CLR(uart_no), UART_FRM_ERR_INT_CLR);
}else if(UART_RXFIFO_FULL_INT_ST == (READ_PERI_REG(UART_INT_ST(uart_no)) & UART_RXFIFO_FULL_INT_ST)){
DBG("f");
uart_rx_intr_disable(UART0);
WRITE_PERI_REG(UART_INT_CLR(UART0), UART_RXFIFO_FULL_INT_CLR);
system_os_post(uart_recvTaskPrio, 0, 0);
}else if(UART_RXFIFO_TOUT_INT_ST == (READ_PERI_REG(UART_INT_ST(uart_no)) & UART_RXFIFO_TOUT_INT_ST)){
DBG("t");
WRITE_PERI_REG(UART_INT_CLR(UART0), UART_RXFIFO_TOUT_INT_CLR);
}else if(UART_TXFIFO_EMPTY_INT_ST == (READ_PERI_REG(UART_INT_ST(uart_no)) & UART_TXFIFO_EMPTY_INT_ST)){
DBG("e");
/* to output uart data from uart buffer directly in empty interrupt handler*/
/*instead of processing in system event, in order not to wait for current task/function to quit */
/*ATTENTION:*/
CLEAR_PERI_REG_MASK(UART_INT_ENA(UART0), UART_TXFIFO_EMPTY_INT_ENA);
#if UART_BUFF_EN
tx_start_uart_buffer(UART0);
#endif
//system_os_post(uart_recvTaskPrio, 1, 0);
WRITE_PERI_REG(UART_INT_CLR(uart_no), UART_TXFIFO_EMPTY_INT_CLR);
}else if(UART_RXFIFO_OVF_INT_ST == (READ_PERI_REG(UART_INT_ST(uart_no)) & UART_RXFIFO_OVF_INT_ST)){
WRITE_PERI_REG(UART_INT_CLR(uart_no), UART_RXFIFO_OVF_INT_CLR);
DBG1("RX OVF!!\r\n");
* FunctionName : uart_init
* Description : user interface for init uart
* Parameters : UartBautRate uart0_br - uart0 bautrate
* UartBautRate uart1_br - uart1 bautrate
* Returns : NONE
#if UART_SELFTEST&UART_BUFF_EN
os_timer_t buff_timer_t;
uart_test_rx()
uint8 uart_buf[128]={0};
uint16 len = 0;
len = rx_buff_deq(uart_buf, 128 );
tx_buff_enq(uart_buf,len);
#endif
LOCAL void ICACHE_FLASH_ATTR ///////
uart_recvTask(os_event_t *events)
if(events->sig == 0){
#if UART_BUFF_EN
Uart_rx_buff_enq();
#else
uint8 fifo_len = (READ_PERI_REG(UART_STATUS(UART0))>>UART_RXFIFO_CNT_S)&UART_RXFIFO_CNT;
uint8 d_tmp = 0;
uint8 idx=0;
for(idx=0;idx<fifo_len;idx++) {
d_tmp = READ_PERI_REG(UART_FIFO(UART0)) & 0xFF;
uart_tx_one_char(UART0, d_tmp);
WRITE_PERI_REG(UART_INT_CLR(UART0), UART_RXFIFO_FULL_INT_CLR|UART_RXFIFO_TOUT_INT_CLR);
uart_rx_intr_enable(UART0);
#endif
}else if(events->sig == 1){
#if UART_BUFF_EN
//already move uart buffer output to uart empty interrupt
//tx_start_uart_buffer(UART0);
#else
#endif
system_os_task(uart_recvTask, uart_recvTaskPrio, uart_recvTaskQueue, uart_recvTaskQueueLen); //demo with a task to process the uart data
UartDev.baut_rate = uart0_br;
uart_config(UART0);
UartDev.baut_rate = uart1_br;
uart_config(UART1);
ETS_UART_INTR_ENABLE();
#if UART_BUFF_EN
pTxBuffer = Uart_Buf_Init(UART_TX_BUFFER_SIZE);
pRxBuffer = Uart_Buf_Init(UART_RX_BUFFER_SIZE);
#endif
/*option 1: use default print, output from uart0 , will wait some time if fifo is full */
//do nothing...
/*option 2: output from uart1,uart1 output will not wait , just for output debug info */
/*os_printf output uart data via uart1(GPIO2)*/
//os_install_putc1((void *)uart1_write_char); //use this one to output debug information via uart1 //
/*option 3: output from uart0 will skip current byte if fifo is full now... */
/*see uart0_write_char_no_wait:you can output via a buffer or output directly */
/*os_printf output uart data via uart0 or uart buffer*/
//os_install_putc1((void *)uart0_write_char_no_wait); //use this to print via uart0
os_timer_disarm(&buff_timer_t);
os_timer_setfn(&buff_timer_t, uart_test_rx , NULL); //a demo to process the data in uart rx buffer
os_timer_arm(&buff_timer_t,10,1);
#endif
uart_reattach()
uart_init(BIT_RATE_115200, BIT_RATE_115200);
* FunctionName : uart_tx_one_char_no_wait
* Description : uart tx a single char without waiting for fifo
* Parameters : uint8 uart - uart port
* uint8 TxChar - char to tx
* Returns : STATUS
uint8 fifo_cnt = (( READ_PERI_REG(UART_STATUS(uart))>>UART_TXFIFO_CNT_S)& UART_TXFIFO_CNT);
if (fifo_cnt < 126) {
return OK;
STATUS uart0_tx_one_char_no_wait(uint8 TxChar)
uint8 fifo_cnt = (( READ_PERI_REG(UART_STATUS(UART0))>>UART_TXFIFO_CNT_S)& UART_TXFIFO_CNT);
WRITE_PERI_REG(UART_FIFO(UART0) , TxChar);
return OK;
* FunctionName : uart1_sendStr_no_wait
* Description : uart tx a string without waiting for every char, used for print debug info which can be lost
* Parameters : const char *str - string to be sent
* Returns : NONE
while(*str){
uart_tx_one_char_no_wait(UART1, *str++);
#if UART_BUFF_EN
* FunctionName : Uart_Buf_Init
* Description : tx buffer enqueue: fill a first linked buffer
* Parameters : char *pdata - data point to be enqueue
* Returns : NONE
struct UartBuffer* ICACHE_FLASH_ATTR
Uart_Buf_Init(uint32 buf_size)
uint32 heap_size = system_get_free_heap_size();
if(heap_size <=buf_size){
DBG1("no buf for uart\n\r");
return NULL;
}else{
DBG("test heap size: %d\n\r",heap_size);
struct UartBuffer* pBuff = (struct UartBuffer* )os_malloc(sizeof(struct UartBuffer));
pBuff->UartBuffSize = buf_size;
pBuff->pUartBuff = (uint8*)os_malloc(pBuff->UartBuffSize);
pBuff->pInPos = pBuff->pUartBuff;
pBuff->pOutPos = pBuff->pUartBuff;
pBuff->Space = pBuff->UartBuffSize;
pBuff->BuffState = OK;
pBuff->nextBuff = NULL;
pBuff->TcpControl = RUN;
return pBuff;
//copy uart buffer
if(data_len == 0) return ;
uint16 tail_len = pCur->pUartBuff + pCur->UartBuffSize - pCur->pInPos ;
if(tail_len >= data_len){ //do not need to loop back the queue
os_memcpy(pCur->pInPos , pdata , data_len );
pCur->pInPos += ( data_len );
pCur->pInPos = (pCur->pUartBuff + (pCur->pInPos - pCur->pUartBuff) % pCur->UartBuffSize );
pCur->Space -=data_len;
}else{
os_memcpy(pCur->pInPos, pdata, tail_len);
pCur->pInPos += ( tail_len );
pCur->Space -=tail_len;
os_memcpy(pCur->pInPos, pdata+tail_len , data_len-tail_len);
pCur->pInPos += ( data_len-tail_len );
pCur->Space -=( data_len-tail_len);
* FunctionName : uart_buf_free
* Description : deinit of the tx buffer
* Parameters : struct UartBuffer* pTxBuff - tx buffer struct pointer
* Returns : NONE
os_free(pBuff->pUartBuff);
os_free(pBuff);
//rx buffer dequeue
uint16 ICACHE_FLASH_ATTR
uint16 buf_len = (pRxBuffer->UartBuffSize- pRxBuffer->Space);
uint16 tail_len = pRxBuffer->pUartBuff + pRxBuffer->UartBuffSize - pRxBuffer->pOutPos ;
uint16 len_tmp = 0;
len_tmp = ((data_len > buf_len)?buf_len:data_len);
if(pRxBuffer->pOutPos <= pRxBuffer->pInPos){
os_memcpy(pdata, pRxBuffer->pOutPos,len_tmp);
pRxBuffer->pOutPos+= len_tmp;
pRxBuffer->Space += len_tmp;
}else{
if(len_tmp>tail_len){
os_memcpy(pdata, pRxBuffer->pOutPos, tail_len);
pRxBuffer->pOutPos += tail_len;
pRxBuffer->pOutPos = (pRxBuffer->pUartBuff + (pRxBuffer->pOutPos- pRxBuffer->pUartBuff) % pRxBuffer->UartBuffSize );
pRxBuffer->Space += tail_len;
os_memcpy(pdata+tail_len , pRxBuffer->pOutPos, len_tmp-tail_len);
pRxBuffer->pOutPos+= ( len_tmp-tail_len );
pRxBuffer->pOutPos= (pRxBuffer->pUartBuff + (pRxBuffer->pOutPos- pRxBuffer->pUartBuff) % pRxBuffer->UartBuffSize );
pRxBuffer->Space +=( len_tmp-tail_len);
}else{
//os_printf("case 3 in rx deq\n\r");
os_memcpy(pdata, pRxBuffer->pOutPos, len_tmp);
pRxBuffer->pOutPos += len_tmp;
if(pRxBuffer->Space >= UART_FIFO_LEN){
return len_tmp;
//move data from uart fifo to rx buffer
uint8 fifo_len,buf_idx;
uint8 fifo_data;
#if 1
if(fifo_len >= pRxBuffer->Space){
os_printf("buf full!!!\n\r");
}else{
buf_idx=0;
while(buf_idx < fifo_len){
buf_idx++;
fifo_data = READ_PERI_REG(UART_FIFO(UART0)) & 0xFF;
*(pRxBuffer->pInPos++) = fifo_data;
if(pRxBuffer->pInPos == (pRxBuffer->pUartBuff + pRxBuffer->UartBuffSize)){
pRxBuffer->pInPos = pRxBuffer->pUartBuff;
pRxBuffer->Space -= fifo_len ;
//os_printf("after rx enq buf enough\n\r");
#endif
//fill the uart tx buffer
if(pTxBuffer == NULL){
DBG1("\n\rnull, create buffer struct\n\r");
if(pTxBuffer!= NULL){
Uart_Buf_Cpy(pTxBuffer , pdata, data_len );
}else{
DBG1("uart tx MALLOC no buf \n\r");
}else{
if(data_len <= pTxBuffer->Space){
Uart_Buf_Cpy(pTxBuffer , pdata, data_len);
}else{
DBG1("UART TX BUF FULL!!!!\n\r");
#if 0
if(pTxBuffer->Space <= URAT_TX_LOWER_SIZE){
set_tcp_block();
#endif
SET_PERI_REG_MASK(UART_CONF1(UART0), (UART_TX_EMPTY_THRESH_VAL & UART_TXFIFO_EMPTY_THRHD)<<UART_TXFIFO_EMPTY_THRHD_S);
SET_PERI_REG_MASK(UART_INT_ENA(UART0), UART_TXFIFO_EMPTY_INT_ENA);
uint8 i;
for(i = 0; i<data_len;i++){
WRITE_PERI_REG(UART_FIFO(uart_no) , *(pTxBuff->pOutPos++));
if(pTxBuff->pOutPos == (pTxBuff->pUartBuff + pTxBuff->UartBuffSize)){
pTxBuff->pOutPos = pTxBuff->pUartBuff;
pTxBuff->pOutPos = (pTxBuff->pUartBuff + (pTxBuff->pOutPos - pTxBuff->pUartBuff) % pTxBuff->UartBuffSize );
pTxBuff->Space += data_len;
* FunctionName : tx_start_uart_buffer
* Description : get data from the tx buffer and fill the uart tx fifo, co-work with the uart fifo empty interrupt
* Parameters : uint8 uart_no - uart port num
* Returns : NONE
uint8 tx_fifo_len = (READ_PERI_REG(UART_STATUS(uart_no))>>UART_TXFIFO_CNT_S)&UART_TXFIFO_CNT;
uint8 fifo_remain = UART_FIFO_LEN - tx_fifo_len ;
uint8 len_tmp;
uint16 tail_ptx_len,head_ptx_len,data_len;
//struct UartBuffer* pTxBuff = *get_buff_prt();
if(pTxBuffer){
data_len = (pTxBuffer->UartBuffSize - pTxBuffer->Space);
if(data_len > fifo_remain){
len_tmp = fifo_remain;
tx_fifo_insert( pTxBuffer,len_tmp,uart_no);
}else{
len_tmp = data_len;
}else{
DBG1("pTxBuff null \n\r");
#endif
#if 1
CLEAR_PERI_REG_MASK(UART_INT_ENA(uart_no), UART_RXFIFO_FULL_INT_ENA|UART_RXFIFO_TOUT_INT_ENA);
#else
ETS_UART_INTR_DISABLE();
#endif
#if 1
SET_PERI_REG_MASK(UART_INT_ENA(uart_no), UART_RXFIFO_FULL_INT_ENA|UART_RXFIFO_TOUT_INT_ENA);
#else
#endif
LOCAL void
uart0_write_char(char c)
if (c == '\n') {
uart_tx_one_char(UART0, '\r');
uart_tx_one_char(UART0, '\n');
} else if (c == '\r') {
} else {
uart_tx_one_char(UART0, c);
SET_PERI_REG_BITS(UART_CONF0(uart_no),UART_BIT_NUM,len,UART_BIT_NUM_S);
SET_PERI_REG_BITS(UART_CONF0(uart_no),UART_STOP_BIT_NUM,bit_num,UART_STOP_BIT_NUM_S);
CLEAR_PERI_REG_MASK(UART_CONF0(uart_no), UART_LINE_INV_MASK);
SET_PERI_REG_MASK(UART_CONF0(uart_no), inverse_mask);
CLEAR_PERI_REG_MASK(UART_CONF0(uart_no), UART_PARITY |UART_PARITY_EN);
if(Parity_mode==NONE_BITS){
}else{
SET_PERI_REG_MASK(UART_CONF0(uart_no), Parity_mode|UART_PARITY_EN);
uart_div_modify(uart_no, UART_CLK_FREQ /baud_rate);
if(flow_ctrl&USART_HardwareFlowControl_RTS){
SET_PERI_REG_BITS(UART_CONF1(uart_no),UART_RX_FLOW_THRHD,rx_thresh,UART_RX_FLOW_THRHD_S);
SET_PERI_REG_MASK(UART_CONF1(uart_no), UART_RX_FLOW_EN);
}else{
CLEAR_PERI_REG_MASK(UART_CONF1(uart_no), UART_RX_FLOW_EN);
if(flow_ctrl&USART_HardwareFlowControl_CTS){
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTCK_U, FUNC_UART0_CTS);
SET_PERI_REG_MASK(UART_CONF0(uart_no), UART_TX_FLOW_EN);
}else{
CLEAR_PERI_REG_MASK(UART_CONF0(uart_no), UART_TX_FLOW_EN);
UART_WaitTxFifoEmpty(uint8 uart_no , uint32 time_out_us) //do not use if tx flow control enabled
uint32 t_s = system_get_time();
while (READ_PERI_REG(UART_STATUS(uart_no)) & (UART_TXFIFO_CNT << UART_TXFIFO_CNT_S)){
if(( system_get_time() - t_s )> time_out_us){
break;
WRITE_PERI_REG(0X60000914, 0X73);//WTD
bool ICACHE_FLASH_ATTR
uint32 t_start = system_get_time();
uint8 tx_fifo_len;
uint32 tx_buff_len;
while(1){
tx_fifo_len =( (READ_PERI_REG(UART_STATUS(uart_no))>>UART_TXFIFO_CNT_S)&UART_TXFIFO_CNT);
if(pTxBuffer){
tx_buff_len = ((pTxBuffer->UartBuffSize)-(pTxBuffer->Space));
}else{
tx_buff_len = 0;
if( tx_fifo_len==0 && tx_buff_len==0){
return TRUE;
if( system_get_time() - t_start > time_out_us){
return FALSE;
WRITE_PERI_REG(UART_INT_CLR(uart_no), clr_mask);
SET_PERI_REG_MASK(UART_INT_ENA(uart_no), ena_mask);
if(uart_no==1){
os_install_putc1(uart1_write_char);
}else{
/*option 1: do not wait if uart fifo is full,drop current character*/
os_install_putc1(uart0_write_char_no_wait);
/*option 2: wait for a while if uart fifo is full*/
os_install_putc1(uart0_write_char);
/*test code*/
uart_init_2(UartBautRate uart0_br, UartBautRate uart1_br)
// rom use 74880 baut_rate, here reinitialize
UartDev.exist_parity = STICK_PARITY_EN;
UartDev.parity = EVEN_BITS;
UartDev.stop_bits = ONE_STOP_BIT;
UartDev.data_bits = EIGHT_BITS;
uart_config(UART0);
uart_config(UART1);
// install uart1 putc callback
os_install_putc1((void *)uart1_write_char);//print output at UART1
Tank you again . I really hope you can help me
Sergio
PostPosted: Wed Apr 11, 2018 4:38 pm
by Giants
Hello i don't understand what happend but the replay i wrote to you last night never arrive. I hope this time work . Anyway here is my code :
Code: Select all#include <ets_sys.h>
#include <osapi.h>
#include "uart.h"
 *                A : rf cal
 *                B : at parameters
 *                C : rf init data
 * Parameters   : none
uint32 ICACHE_FLASH_ATTR
    switch (size_map) {
            rf_cal_sec = 128 - 5;
            break;
            break;
            break;
            break;
        default:
            rf_cal_sec = 0;
            break;
    return rf_cal_sec;
   ets_wdt_enable();
   ets_wdt_disable();
   gpio_init();
   for(;;)
Help me about your frase "I have heard that many times before, and it was often not true." the power supply is 3,4V i miss something ?
RST is connect to Vcc with one pullup 10K
CH_PD is connect to Vcc with one pullup 10K
GPIO 0 is connect to Vcc with one pullup 10K
GPIO 2 is free
Thank you
Sergio
