Fixed Frequency
Posted: Thu Apr 26, 2018 2:41 am
I am trying to set the frequency of the wifi to a certain wifi channel band. I know there is a function in the SDK that allow this but how does the parameters relate to the wifi frequency channels i.e https://en.wikipedia.org/wiki/List_of_WLAN_channels.
Unfortunately I do not have a way to directly test the frequencies myself.
enum FIXED_RATE {
PHY_RATE_48 = 0x8,
PHY_RATE_24 = 0x9,
PHY_RATE_12 = 0xA,
PHY_RATE_6 = 0xB,
PHY_RATE_54 = 0xC,
PHY_RATE_36 = 0xD,
PHY_RATE_18 = 0xE,
PHY_RATE_9 = 0xF
#define FIXED_RATE_MASK_NONE 0x00
#define FIXED_RATE_MASK_STA 0x01
#define FIXED_RATE_MASK_AP 0x02
#define FIXED_RATE_MASK_ALL 0x03
* @brief Set the fixed rate and mask of sending data from ESP8266.
* @attention 1. Only if the corresponding bit in enable_mask is 1, ESP8266 station
* or soft-AP will send data in the fixed rate.
* @attention 2. If the enable_mask is 0, both ESP8266 station and soft-AP will not
* send data in the fixed rate.
* @attention 3. ESP8266 station and soft-AP share the same rate, they can not be
* set into the different rate.
* @param uint8 enable_mask : 0x00 - disable the fixed rate
* - 0x01 - use the fixed rate on ESP8266 station
* - 0x02 - use the fixed rate on ESP8266 soft-AP
* - 0x03 - use the fixed rate on ESP8266 station and soft-AP
* @param uint8 rate : value of the fixed rate
* @return 0 : succeed
* @return otherwise : fail
sint32 wifi_set_user_fixed_rate(uint8 enable_mask, uint8 rate);
