By Davidb
#78202 Hi all,
I am using an OBD2 adapter which is working fine together with arduino nano and following code :
Code: Select all#include <LiquidCrystal.h>
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);           // select the pins used on the LCD panel
#include <OBD2UART.h>
COBD obd;
void setup()
  // we'll use the debug LED as output
  // start communication with OBD-II UART adapter
  obd.begin();
  lcd.begin(16, 2);
  // initiate OBD-II connection until success
  while (!obd.init());
void loop()
  int value;
  obd.readPID(PID_RPM, value);
  int value2;
  obd.readPID(PID_COOLANT_TEMP, value2);
  lcd.setCursor(0,0);
  lcd.print("RPM = ");
  lcd.print(value);
  lcd.print("     ");
  lcd.setCursor(0,1);
  lcd.print("ECT = ");
  lcd.print(value2);
  lcd.print("     ");
Connection is very simple: gnd - gnd / rx and tx
My problem is that if I use a nodemcu board instead of nano the code is blocking on " while (!obd.init()); ".
Any idea why ?
Thanks a lot in advance.
