rudy wrote:I can't say what is best for you. I prefer thermocouples as that is what I am familiar with. The processes that i have dealt with had thermocouples originally so I stuck with it. Thermocouples need to be connected with thermocouple wire of the same type. The resistance of the wire connecting the RTDs is a factor that needs to be considered. With thermocouples resistance is not significant.
In the end the choice is always a consideration of many factors.
If you are considering thermocouples then look at MAX31856. It would be my first choice in a new design.
https://www.adafruit.com/product/3263
https://www.aliexpress.com/item/MAX3185 ... 82894.html
I understand, your best case is thermocouple! I'm also facing this, meeting some customers but still can not tell when they both have 2 strands, they look pretty. Perhaps there is a difference between their resistance that characterizes each one.
Very good the chips, it is easy to confuse, because the names are very similar between the MAX that le PT100 and what thermocouple.
I did not find here in my country to buy the MAX31856, I found the MAX6675. Do you know the difference between them? I will use commercial to automate some things, I must begin to take one that I will buy in greater quantity.
