Every 20 seconds, wemos send a "life signal" to pc in order to keep the client connected. That part works actually very well; I let both (wemos and PC) on all night long and everything went fine.
When I start to mess around with the encoder, problems begin... I move the encoder and data is sent, but if a start moving the encoder REAL FAST back and forward, gives me and exception and everything fails. I've tried to limitate the time between packets, but problems keep going...
I commented the line part when I send the data -"client.println (mensaje);"- and doing the same action mentioned I have no exception, so, I thing problem is on the sending part... (I think...)
How can I manage this issue? Thanks in advance!
//---------------------------------------------Librerías para incluir
//---------------------------------------------Definición de variables
#define pinD1 D1
#define pinD2 D2
#define pinD7 D7
#define pinD5 D5
#define pinD6 D6
WiFiClient client;
int contador = 0;
int lastEncState = LOW;
String tempMsg;
unsigned long timeout;
int countPackets;
unsigned long lastIndState = 0;
unsigned long lastPacket = 0;
int lastPacketMin = 0; //Tiempo mínimo entre paquetes para envio
const char* ssid = "ProyeccionesCorp"; //Nombre de la RED WIFI a conectarse (SSID)
const char* password = "cordoba392"; //Contraseña de RED WIFI
const String Wemos0 = "enc0";
const String Wemos1 = "enc1";
const String Wemos2 = "enc2";
const String Wemos3 = "enc3";
String mainVar = "";
bool useDHCP = false; //Indica si obtiene dirección IP del servidor DHCP, de lo contrario, carga los siguiente valores
IPAddress staticIP (192, 168, 0, 0);
IPAddress staticIP0(192, 168, 50, 201); //IP estática de ésta terminal Wemos (0)
IPAddress staticIP1(192, 168, 50, 202); //IP estática de ésta terminal Wemos (1)
IPAddress staticIP2(192, 168, 50, 203); //IP estática de ésta terminal Wemos (2)
IPAddress staticIP3(192, 168, 50, 204); //IP estática de ésta terminal Wemos (3)
IPAddress gateway(192, 168, 1, 1); //IP del Ruter (Gateway)
IPAddress subnet(255, 255, 255, 0); //Máscara de SubRed
IPAddress ipDestino(192, 168, 50, 174); //Dirección IP a donde se enviarán paquetes UDP
const int puertoRemoto = 4445; //Puerto remoto para enviar UDP
const char* deviceName = "WemosD1ProMini"; //Nombre del Dispositivo
char replyPacket[] = "A"; //Buffer de carga para envio de mensajes UDP
//---------------------------------------------SETUP
ESP.wdtEnable(1000);
delay(100);
bool A, B;
int temp;
A = digitalRead (pinD5);
B = digitalRead (pinD6);
if (!A && !B) {temp = 0;}
if (A && !B) {temp = 1;}
if (!A && B) {temp = 2;}
if (A && B) {temp = 3;}
switch (temp){
case 0:
staticIP = staticIP0;
mainVar = Wemos0;
break;
case 1:
staticIP = staticIP1;
mainVar = Wemos1;
break;
case 2:
staticIP = staticIP2;
mainVar = Wemos2;
break;
case 3:
staticIP = staticIP3;
mainVar = Wemos3;
break;
pinMode(pinD7, INPUT);
pinMode(pinD1, INPUT);
pinMode(pinD2, INPUT);
pinMode(pinD5, INPUT);
pinMode(pinD6, INPUT);
attachInterrupt(digitalPinToInterrupt(pinD1), doEnc, RISING ); //Seteo de Interrupcion para Encoder A
attachInterrupt(digitalPinToInterrupt(pinD2), doEnc, RISING ); //Seteo de Interrupcion para Encoder B
attachInterrupt(digitalPinToInterrupt(pinD7), doInductivo, RISING ); //Seteo de Interrupcion para Encoder B
Serial.printf("Enviando datos a IP %s, en el Puerto %d", ipDestino.toString().c_str(), puertoRemoto);
Serial.print (F(" con la variable "));
Serial.println (mainVar);
Serial.print ("Se utilizará la dirección IP ");
Serial.println (staticIP);
Serial.println("Sistema Listo");
void connectWIFI(){
if (WiFi.status() == 6) {
Serial.print("Conectando a la red ");
Serial.println(ssid);
WiFi.mode(WIFI_STA);
WiFi.config(staticIP, subnet, gateway);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("WiFi conectado!");
Serial.print("IP Local: ");
//---------------------------------------------LOOP
void loop(){
if (WiFi.status() != WL_CONNECTED){
connectWIFI();
}else{
if (client.connected() == 0){
Serial.println("Cliente desconectado. Intentando Conectar...");
connectToWO (3040);
}else{
unsigned long temp = millis() - lastPacket;
if (temp > 20000){
sendTCP("authenticate 1", 3039);
sendTCP("authenticate 1", 3040);
//---------------------------------------------CONNECTTOWO
void connectToWO (int port){
Serial.print("Conectando a ");
Serial.print(ipDestino);
Serial.print(':');
Serial.println(port);
if (!client.connect(ipDestino, port)) {
Serial.println("Falló la conexión");
delay(1000);
return;
}else{
Serial.print ("Conectado exitosamente a ");
Serial.println (ipDestino);
timeout = millis();
//---------------------------------------------SENDUDP
void sendTCP(String mensaje, int puerto){
if (temp >= lastPacketMin){
Serial.println("Cliente desconectado. Intentando Reconectar...");
connectToWO (puerto);
}else{
Serial.print(F("Enviando a "));
Serial.print(F(":"));
Serial.print(puerto);
Serial.print(F(" el valor: "));
Serial.println (mensaje);
lastPacket = millis();
}else{
Serial.println ("Port Overflow");
//---------------------------------------------DOENC
void doEnc(){
ESP.wdtFeed();
int A = digitalRead (pinD1);
int B = digitalRead (pinD2);
if ((lastEncState == LOW) && (A == HIGH)) {
if (B == LOW) {
contador--;
} else {
contador++;
tempMsg = "setInputs 0 " + mainVar + " " + String(contador);
sendTCP(tempMsg, 3040);
lastEncState = A;
//---------------------------------------------DOINDUCTIVO
void doInductivo(){
if (millis () - lastIndState > 1000){
contador = 0;
Serial.println(F("+++ Inductivo activado +++"));
lastIndState = millis();
