How to display SPIFSS directory listing on webpage
Posted:
Sat Dec 01, 2018 5:35 pm
by Espradio01
Hi All
I'm hoping someone here would kindly share an example of how to list the content of spiffs on a webpage.
I am currently able to upload to spiffs.
It would be great to be able to download too (not by using the ftp server example unless it's a modified version)
I have managed to create a text file that i have written to but would like to beale to :
1. check it's there
2. Download it (or check its content on the esp's web page)
Thank you kindly
Den
Re: How to display SPIFSS directory listing on webpage
Posted:
Sun Dec 02, 2018 4:07 am
by btidey
Check out
https://github.com/esp8266/Arduino/tree ... /FSBrowserThis allows you to upload, download, delete, view, edit
Posted:
Mon Dec 03, 2018 12:46 pm
by quackmore
that's funny, I'm working on that right now ...
I'm using SDK and I'm developing a web api for this
// [GET] /api/files/ls
// [GET] /api/files/cat/:name
// [POST] /api/files/delete/:name
// [POST] /api/files/create/:name
hope this will help you (and may your comments will help me ...)
cheers
listing looks like this (this is the web server receiving function, I've cut some code just for showing big view)
if ((0 == os_strcmp(parsed_req.url, "/api/files/ls")) && (parsed_req.req_method == HTTP_GET))
if (espfs.is_available()) // if file system is available
// count files first -> file_cnt
// now prepare the list
char *file_list = (char *)os_zalloc(32 + (file_cnt * (32 + 3)));
if (file_list)
char *tmp_ptr = file_list;
os_sprintf(file_list, "{\"files\":["); // returning results with a JSON string
// for listing with SPIFFS checkout SPIFFS using
// the following uses my C++ wrapper
file_ptr = espfs.list(0);
while (file_ptr)
tmp_ptr = file_list + os_strlen(file_list);
if (tmp_ptr != (file_list + os_strlen("{\"files\":[")))
*(tmp_ptr++) = ',';
os_sprintf(tmp_ptr, "\"%s\"", (char *)file_ptr->name);
file_ptr = espfs.list(1);
os_sprintf(tmp_ptr, "]}\n");
response(ptr_espconn, HTTP_OK, file_list, true);
return;
else
esplog.error("Websvr::webserver_recv - not enough heap memory\n");
return;
else
response(ptr_espconn, HTTP_SERVER_ERROR, "File system is not available\n", false);
return;
