- Tue Jan 29, 2019 11:20 am
#80330
01/29/2019
Project sketch is executing without a wdt_reset; it is still a little "touchy" initiating a client "GET" request. Over-all much improved. File, fileRead function is once again fully functional.
Some of the problem was with the GPIO pins I was attempting to use. Current GPIO pin used for espsoftwaresaerial are GPIO5 for TX, GPIO4 for RX, DS3231 uses GPIO2 for SDA, and GPIO0 for SCL. Project board is a RobotDyn WiFi D1 R2. Board looks like a clone of the WeMos WiFi D1 R2.
Project uses a DS3231 for time keeping and will be updated by a Neo m8n GPS module. I am having a "false" value for unixtime in the function RTC_UPDAE. Unixtime value is almost double. Standalone sketch "Get_unixtime.ino" gives correct unixtime value. Intergrating it into project gives about twice the value for unixtime.
Get_unixtime.ino:
[code#include <time.h>
#include <stdio.h>
struct tm timeinfo;
unsigned int unixtime;
printf("hello\n");
timeinfo.tm_year = 2017 - 1900;
timeinfo.tm_mon = 12 - 1;
timeinfo.tm_mday = 13;
timeinfo.tm_hour = 16;
timeinfo.tm_min = 46;
timeinfo.tm_sec = 45;
unixtime = mktime(&timeinfo);
printf("time = %u\n", unixtime);
// return 0;
void loop(){}][/code]
RTC_UPDATE function:
Code: Select allvoid RTC_UPDATE()
ESP.wdtDisable();
Serial.println("");
Serial.print(F("GPS UTC Date/Time: "));
if (gps.date.isValid())
Serial.print(gps.date.month());
Serial.print(F("/"));
Serial.print(gps.date.day());
Serial.print(gps.date.year());
Serial.print(F("INVALID"));
Serial.print(F(" "));
if (gps.time.isValid())
if (gps.time.hour() < 10) Serial.print(F("0"));
Serial.print(gps.time.hour());
Serial.print(F(":"));
if (gps.time.minute() < 10) Serial.print(F("0"));
Serial.print(gps.time.minute());
if (gps.time.second() < 10) Serial.print(F("0"));
Serial.print(gps.time.second());
Serial.print(F("."));
if (gps.time.centisecond() < 10) Serial.print(F("0"));
Serial.print(gps.time.centisecond());
Serial.println("");
struct tm timeinfo;
unsigned long int unixtime;
timeinfo.tm_year = gps.date.year() - 1970;
timeinfo.tm_mon = gps.date.month() - 1;
timeinfo.tm_mday = gps.date.day();
timeinfo.tm_hour = gps.time.hour();
timeinfo.tm_min = gps.time.minute();
timeinfo.tm_sec = gps.time.second();
Serial.println("");
printf("unixtime = %u\n", unixtime);
Clock.setDateTime(unixtime);
Serial.println("RTC updated");
ESP.wdtEnable(1000);
Any issues with the RTC_UPDATE function; that would cause the unixtime variable to be almost twice the expected value?
William
Featuring web interface, graphs, rain gauge, and
GPS --still a work in progress. Working concept demo.
(21.83 KiB) Downloaded 170 times
Screen captures, text files and board pinout.
(1.65 MiB) Downloaded 163 times
