- Sat Dec 22, 2018 3:34 am
#79680
Hi, this is my simple code:
#include <PubSubClient.h>
// Update these with values suitable for your network.
const char* ssid = "zaatari";
const char* password = "EC6D0D7169";
const char* mqtt_server = "192.168.1.91";
WiFiClient espClient;
PubSubClient client(espClient);
long lastMsg = 0;
char msg[50];
int value = 0;
const int curstate =14;
int inplaststate =0;
int outs =0;
const int outpt =2;
int inpcurstate=0;
void setup_wifi() {
delay(10);
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
randomSeed(micros());
Serial.println("");
void callback(char* topic, byte* payload, unsigned int length) {
Serial.print("Message arrived [");
Serial.print(topic);
Serial.print("] ");
for (int i = 0; i < length; i++) {
Serial.print((char)payload[i]);
// Switch on the LED if an 1 was received as first character
if ((char)payload[0] == '1') {
digitalWrite(BUILTIN_LED, LOW); // Turn the LED on (Note that LOW is the voltage level
// but actually the LED is on; this is because
// it is acive low on the ESP-01)
} else {
digitalWrite(BUILTIN_LED, HIGH); // Turn the LED off by making the voltage HIGH
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Create a random client ID
String clientId = "ESP8266Client-";
clientId += String(random(0xffff), HEX);
// Attempt to connect
if (client.connect(clientId.c_str())) {
Serial.println("connected");
// Once connected, publish an announcement...
//client.publish("outTopic", "hello world");
// ... and resubscribe
// client.subscribe("inTopic");
} else {
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
pinMode(BUILTIN_LED, OUTPUT); // Initialize the BUILTIN_LED pin as an output
pinMode(curstate,INPUT_PULLUP);
pinMode(outpt,OUTPUT);
digitalWrite(outpt,HIGH);
setup_wifi();
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
if (!client.connected()) {
reconnect();
client.loop();
inpcurstate = digitalRead(curstate);
delay(50);
if((inpcurstate == LOW)&&(inpcurstate != inplaststate))
Serial.println("HI");
outs = digitalRead(outpt);
if(outs == HIGH)
digitalWrite(outpt,LOW);
Serial.println("ON");
client.publish("hmia", "1on");
Serial.println("OFF");
client.publish("hmia", "0of");
inplaststate = inpcurstate;
I appreciate your help, and it solved when I change IwIP Variant from v2 Lower Memory to v1.4 Higher Bandwidth in IDE Tool Menu.
Thanx a lot
