The are doing a great job
Explore... Chat... Share...
McHubby007 wrote:
kenn wrote:
davydnorris wrote:
quackmore wrote:
McChubby007 wrote:I'm glad that we gave enough info for you to make an informed decision and that it is most likely the correct one.
It's good that you have explained your experience as this may help others to decide also. I think it is essential to make the decision early-on after the Arduino IDE has become tiresome as we all invest our time/effort into learning an IDE and it is painful having to change. I think I would have used platformIO immediately if it had been available when I started with esp8266. Once I move to esp32 work on platformIO I will most likely move all my esp8266 stuff over to it also.
Yes, unless you are planning to hack the esp core or use development versions not published in PlatformIO's database then it is definitely a more user friendly environment than Eclipse. I'm looking forward to doing some esp32 development with platformIO and the debugger as I have bought a JTAG adapter especially to work with it. See http://docs.platformio.org/en/latest/tu ... sting.html
