- Thu Apr 04, 2019 8:53 pm
#81565
While that's quite a neat hack, it's actually not really measuring voltage - it's using voltage to measure the resistance of the potentiometers in the analog joystick.
If your situation is the same then there's no reason why you couldn't use a similar set up to power several resistances with a GPIO each and then measure them individually.
If you're actually looking to measure in circuit voltage then you're not going to be able to use that approach, and I would look for some sort of I2C based multiple input ADC - something like the LTC2309, which is an 8 channel 12 bit ADC with I2C interface
