* Sketch: ESP8266_LED_Control_02C
* Now with added CSS and a single button
* Control an LED from a web browser
* Intended to be run on an ESP8266
* connect to the ESP8266 AP then
* use web broswer to go to 192.168.4.1
const char WiFiPassword[] = "12345678";
const char AP_NameChar[] = "LEDControl" ;
WiFiServer server(80);
String header = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n";
String html_1 = "<!DOCTYPE html><html><head><meta name='viewport' content='width=device-width, initial-scale=1.0'/><meta charset='utf-8'><style>body {font-size:140%;} #main {display: table; margin: auto; padding: 0 10px 0 10px; } h2,{text-align:center; } .button { padding:10px 10px 10px 10px; width:100%; background-color: #4CAF50; font-size: 120%;}</style><title>LED Control</title></head><body><div id='main'><h2>LED Control</h2>";
String html_2 = "";
String html_4 = "</div></body></html>";
String request = "";
int LED_Pin = D1;
void setup()
pinMode(LED_Pin, OUTPUT);
boolean conn = WiFi.softAP(AP_NameChar, WiFiPassword);
server.begin();
} // void setup()
void loop()
if (!client) { return; }
request = client.readStringUntil('\r');
if ( request.indexOf("LEDON") > 0 ) { digitalWrite(LED_Pin, HIGH); }
else if ( request.indexOf("LEDOFF") > 0 ) { digitalWrite(LED_Pin, LOW); }
// Get the LED pin status and create the LED status message
if (digitalRead(LED_Pin) == HIGH)
// the LED is on so the button needs to say turn it off
html_2 = "<form id='F1' action='LEDOFF'><input class='button' type='submit' value='Turn of the LED' ></form><br>";
// the LED is off so the button needs to say turn it on
html_2 = "<form id='F1' action='LEDON'><input class='button' type='submit' value='Turn on the LED' ></form><br>";
client.flush();
client.print( header );
client.print( html_1 );
client.print( html_2 );
client.print( html_4);
delay(5);
// The client will actually be disconnected when the function returns and 'client' object is detroyed
} // void loop()
I was hoping to be able to change it so that instead of turning the LED on, it would make it blink. I have close to zero experience with Arduino, but I tried a couple things to see if I could get it to work. Here's what I was hoping would work:
for(int i = 0; i < 1000; i++)
delay(1000);
When I upload this and go to the address, I can turn on the LED, but it doesn't blink. Additionally, I cannot turn off the LED. I'd appreciate it if someone could let me know what I am doing wrong and tell me the correct way to do it. Thanks!
