Error running sketches on WeMos D1 R1
Posted: Mon Feb 10, 2020 6:12 pm
Hi guys,
just starting out on the ESP8266 platform so forgive my ignorance on what might be obvious...
After being able to successfully compile and upload the blink sketch on a WeMos R1 D1 I'm now getting error messages for any sketch.
Now getting the message "esptool.FatalError: Invalid head of packet (0x46)"
Scanning through the log, what caught my attention is the message about the crystal frequency...
WARNING: Detected crystal freq 20.39MHz is quite different to normalized freq 26MHz. Unsupported crystal in use?
Crystal is 26MHz
Could this be a hardware issue?
Interestingly the monitor seems to work looking at the COM port and when I press Reset on the board the boars seems to respond without any errors. I can connect to the http server from my mobile
Monitor out attached
_______________________________________
Arduino: 1.8.10 (Windows 10), Board: "WeMos D1 R1, 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, All Flash Contents, 921600"
Executable segment sizes:
IROM : 227612 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 26776 / 32768 - code in IRAM (ICACHE_RAM_ATTR, ISRs...)
DATA : 1252 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 672 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 24880 ) - zeroed variables (global, static) in RAM/HEAP
Sketch uses 256312 bytes (24%) of program storage space. Maximum is 1044464 bytes.
Global variables use 26804 bytes (32%) of dynamic memory, leaving 55116 bytes for local variables. Maximum is 81920 bytes.
esptool.py v2.8
Serial port COM4
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: 00:08:ff:00:00:00
Uploading stub...
Running stub...
File "C:\Users\tfmei\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.3/tools/upload.py", line 65, in <module>
esptool.main(cmdline)
File "C:/Users/tfmei/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/esptool\esptool.py", line 2909, in main
esp = esp.run_stub()
File "C:/Users/tfmei/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/esptool\esptool.py", line 637, in run_stub
p = self.read()
File "C:/Users/tfmei/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/esptool\esptool.py", line 292, in read
return next(self._slip_reader)
File "C:/Users/tfmei/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/esptool\esptool.py", line 2057, in slip_reader
raise FatalError('Invalid head of packet (0x%s)' % hexify(b))
Crystal is 26MHz
esptool.py v2.8
Serial port COM4
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
Uploading stub...
Running stub...
p = self.read()
