My code is for an ESP8266 and nothing else.
https://lastminuteengineers.com/esp8266 ... duino-ide/
But if you was not aware of that, you cannot help anyway.
Thank you for answering.
Explore... Chat... Share...
RIN67630 wrote:The ArduinoOTA.handle(); has been named that way historically since the IDE used is the same.
I'd like to use the TXD pin as an input. This inpu[…]
Thomas, I am not sure I really understand. However[…]
Unfortunately, the WSS connection broken since las[…]
also, you may want to check out what thingspeak do[…]
Hi, I use two same javascript function I change ju[…]
Except for D8 (GPIO15, which has to be pulled LOW […]
I've not used (or really taken a look at) ESPNow, […]
How did you connect GPIO16 to RST? You should idea[…]
1. Does anyone know which Modbus RTU library for e[…]
I believe the suffix is primarily a revision indic[…]
Why do you want so much mess in programming? Just […]
Follow US on Twitter and get ESP8266 news and updates first.
