Kindly guide with connect DC submersible pump with relay
Posted: Thu Jan 14, 2021 2:40 pm
I am designing a project where my need to control a 3-6V DC submersible pump using relay motor and LIPO battery, I am supplying voltage to relay using my MB102 breadboard power supply and dc pump through LIPO battery through relay module ,On pressing the push button of my MB102 breadboard powersupply the relay triggers and starts the pump and quickly turns off the .pump , pump is fine as checked earlier as well
video-= https://gofile.io/d/AYz5OF
My code
int relayInput = D2; // the input to the relay pin
pinMode(relayInput, OUTPUT); // initialize pin as OUTPUT
digitalWrite(relayInput, HIGH); // turn relay on
delay(1000);
digitalWrite(relayInput, LOW); // turn relay off
delay(1000);
I also tried making delay(60000) to wait for 1min but there is no outcome ..kindly help
image of circuit
My code
delay(1000);
delay(1000);
image of circuit
