By UniqueIdentifier
#91232 I've got a ESP8266 with HC-SR501 PIR that I've solvered to the board for 3.3v operation.
When I run a very simple code on it, it works perfectly.
With the same wiring setup, and the same code as part of a larger program utilizing the temp sensor just before it, it seems to always read on?
Here is the simple code and the output. It detects the moition and comes on right away.
Code: Select allint ledPin = 13;                // choose the pin for the LED
int inputPin = 4;               // choose the input pin (for PIR sensor)
int pirState = LOW;             // we start, assuming no motion detected
int val = 0;                    // variable for reading the pin status
  pinMode(ledPin, OUTPUT);      // declare LED as output
  pinMode(inputPin, INPUT);     // declare sensor as input
  Serial.println("Starting up");
void loop(){
  val = digitalRead(inputPin);  // read input value
  Serial.println((String)"the value of val is " +val);
  if (val == HIGH)  // check if the input is HIGH
    Serial.println("Motion is on");
    if (pirState == LOW)
      Serial.println("Motion detected!"); // print on output change
      pirState = HIGH;
    digitalWrite(ledPin, LOW); // turn LED OFF
    if (pirState == HIGH)
      Serial.println("Motion ended!");  // print on output change
      pirState = LOW;
Here is the code that seems to give erroneous reads
Code: Select allvoid do_board_function() {   // This boards function is to get and send DHT temp/humity to MQTT
  Serial.println("");
  Serial.println("Starting Board Functions");
  //////START - TEMP + HUM//////
  float readt = dht.readTemperature();
  delay(2000);
  float readh = dht.readHumidity();
  // Check if any reads failed and exit early (to try again).
  if (isnan(readt)) {
  else {
    Serial.print("Temperature = ");
    Serial.print(readt);
    Serial.print(" .... ");
    Serial.print("Humidity = ");
    Serial.print(readh);
    String temp_strt = String(readt);
    String hum_strt = String(readh);
    temp_strt.toCharArray(temp, temp_strt.length() + 1); //packaging up the data to publish to mqtt
    String temp_strh = String(readh);
    hum_strt.toCharArray(hum, hum_strt.length() + 1); //packaging up the data to publish to mqtt
    // String MQTTPublish = String("Temperature is" + t + "Humidity is" + h);
    client.publish(Topic_DataMessagesTemp, temp);
    client.publish(Topic_DataMessagesHum, hum);
    //////END - TEMP + HUM//////
    //New Motion Sensor code
   val = digitalRead(MOTIONPIN);  // read input value
      pirState = HIGH;
      pirState = LOW;
I have tried to wrap the sensor in tinfoil thiking it was itnerference but I honestly have no idea....
Attached is the pictures showing the working and non working and my wiring. The motion sensor is on pin D2 and the temp sensor read put is D1..
By bra1n
#91233 PIR sensors are very sensitive to interference and the WiFi transmission of the ESP8266 can cause problems. I ended up moving my PIR a few metres away from the the ESP, connecting it with screened cable and filter caps at each end. This greatly improved matters although I still get the odd false trigger, I'm thinking of installing a second PIR a few metres away and applying some logic that requires both to be triggered within a short time interval for a positive movement detection.
By UniqueIdentifier
#91240
bra1n wrote:PIR sensors are very sensitive to interference and the WiFi transmission of the ESP8266 can cause problems. I ended up moving my PIR a few metres away from the the ESP, connecting it with screened cable and filter caps at each end. This greatly improved matters although I still get the odd false trigger, I'm thinking of installing a second PIR a few metres away and applying some logic that requires both to be triggered within a short time interval for a positive movement detection.
Are oyu using the SR501 or a AMS? THis sseems like a major PITA to run two sesnsors. I've tried to cover mine up with tinfoil to protect it.. same thing.. Looking at using interupts rather than polling...
What are you using?
By btidey
#91244 The wifi signal can certainly cause lots of false triggering with PIR sensors.
One technique that can be used in some cases is to turn the wifi off and only turn it on after a PIR signal has been detected. This works in cases where you just want to action the PIR and report it. It is also applicable in battery operated scenarios where the device is in deep sleep (with wifi off obviously) and the PIR signal is used as the wake up trigger.
One downside is making OTA a little more tricky but there are strategies that can be used for that.
