A.T.&T router is a Arris NVG588.
Has anyone else experience this issue? Any work around to fix this issue?
William
(11.77 KiB) Downloaded 50 times
Explore... Chat... Share...
Sirquil wrote:Have a ESP8266, sump pit monitor that uses NTP; it works perfectly with our Xfinity, network router. ESP8266 connects to the AT&T router; does not receive UDP packets. Firewall has been configured on the NVG588; still, does not work. UDP port is defined as 1337.
A.T.&T router is a Arris NVG588. drift hunters
William
Hi, Did you manage to get your sensor working ? […]
Hi guys! (sorry for not presenting, but not the t[…]
Hi, I'm testing BLYNK ON MEGA+WiFi R3 ATmega2560+E[…]
Hi rudy, thanks a lot! I searched for hours for th[…]
Hi, I request you to test the ESP8266-12F board se[…]
Are the ESPs alright? I mean can you upload codes […]
The AT 2 binary for esp8266 build by Espressif use[…]
Thank you, that answers my major question. Rathe[…]
Here is a good design of a NodeMcu power supply. […]
Did you actually manage to fix this problem? I kno[…]
Follow US on Twitter and get ESP8266 news and updates first.
