Re: Flashing fw stops after 20 seconds
Posted:
Sat Nov 07, 2015 4:52 pm
by ricardojlrufino
I have problem when using a cheap FTDI module bought from China (on LINUX).
To flash firmware I use Arduino UNO board (original) as described here:
https://ricardojlrufino.wordpress.com/2 ... rduino-uno
Posted:
Tue Nov 24, 2015 5:21 am
by desertwalker66
I also had issues flashing MCU firmware onto esp8266 module using my Macbook (Yosemite). After coming to this page and using the advice of mr Morse it worked flawlessly.
I opened my terminal in mac, navigated to the folder containing esptool.py ( e.g. Documents/Arduino/esptool/) and opened up the file esptool.py with vim ( desertwalker+>: vim esptool.py) I changed the packet sizes from 1800 --> 180 & 400 --> 40
I then used the vim command :wq to write file and exit.
Returned to terminal and typed in command desertwalker+>:python esptool.py --port /dev/tty.usbserial-A50285BI write_flash 0x00000 ~/Documents/Arduino/esp8266/nodemcu_20150127.bin or whatever is appropriate to you.( I saved the firmware bin file to esp8266 folder ).
As mentioned, not a falter. Just wanted to say thank you to Mr Morse for your help, saved me heap um big hassles.
Posted:
Sun Nov 29, 2015 3:08 pm
by oscarute
Mr.Morse wrote:This is what I did to flash my ESP8266 - 01 from my windows pc
- Wire it up like this
- Install python 2.7 download here
- Install pyserial download here
- Download to the esptool.py from here save it in the pyton installation folder
- Download nodemcu_latest.bin from here and save it in the python installation folder
- Edit esptool.py so that:
ESP_RAM_BLOCK = 0x180
ESP_FLASH_BLOCK = 0x40
- Open cmd and go to the python folder and type in this (change the COM7 to whatever your FTDI is)
esptool.py -p COM7 write_flash 0x000000 nodemcu_latest.bin
Thanks, It's working but I had to change to lower baud rate...
ESP_ROM_BAUD = 74440
Posted:
Thu Dec 31, 2015 1:15 am
by Subhan95
hi
I wonder if you found any solutions to this problem.I have the same problems you described.
