Re: Going out of AP range kills module
Posted:
Wed Oct 08, 2014 11:52 am
by spacejunkie
It does not have baud rate control at the moment but I can add it over the weekend
Posted:
Wed Oct 15, 2014 1:38 pm
by spacejunkie
scargill wrote:Spacejunkie - is your firmware based on the latest version i.e. 0018000902 (which is actuallly 922 but reports 902) with baud rate control) or an earlier one - if based on the latter this would be wonderful as that "busy" is a pain...
Here it is. It starts up at 9600 bps. You can then change it to any baud using
or
and ofcourse you can reset using
Posted:
Wed Oct 15, 2014 5:49 pm
by scargill
Absolutely wonderful - loaded up the new code first time.. but... is it really necessary to reset the baud rate? All I would imagine most people want is to get out of the mess.. so if I am say running a socket listener or a web server and it locks up with busy.. I guess I want the same as would happen with a hard reset.. ie in the case of a web server, for it to reset, auto connect back to the router (as it does when it resets) and require only the relevant mode setting. Am I right in saying here that everything needs to be setup after AT+XRST... actually in an ideal world we just need that damned BUSY to time out... but maybe for now that's asking too much... thoughts? And thanks again for doing this..
Posted:
Wed Oct 15, 2014 6:06 pm
by scargill
Something has changed in your update... the baud rate once set, would previously stay there. It is now defaulting back to 9600 on power up every time - which means having to change baud rate programmatically during set up every powerup.. Did you intend that?
